Question about Compaq Presario Notebook
Wireless internet access not working; getiing orange led
Wireless internet access stop working. Getting orange LED instead of blue. Can get access through wired connection.
  • 3 Answers
Anyone having a wlan/wireless problem with a compaq F730us, please report it to HP corporate headquarters and HP/Compaq. The problem is with the mainboard, its a manufacturer problem. Only HP/Compaq can fix this for free, but we have to let them know that the F700 series is also having the same hardware issues as the f500 and other series. Here is a link to hp website so you can see that hp is aware of the problem, we just need to get the f700's added to the list.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=uk&docname=c01480071&dlc=en
and
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01087277
Here is also a website for people everywhere experiencing the same problems w/compaq wireless not working. HP/compaq needs to correct this.
http://forums.windowsvistamagazine.com/forums/3/7808/ShowThread.aspx
Posted on May 25, 2009
My Netgear WPN824 wireless router stopped working. With the exception of the internet LED (which doesn't come on at all), all of the lights are blue and doing sort of a slow, pulsating blink. No m
The RESET button is for resetting the wireless section of the router and does not effect the Internet connection.
It looks like the wireless access is faulty especially when you cannot reset and configure the wireless settings.
Try powering off the Netgear for 10 mins the connect the power again.
If you still cannot RESET the Netgear then it is faulty and you need a new wireless router.
Mar 07, 2013 | NetGear RangeMax WPN824 Wireless Router...
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
No wi-fi signal transmitted
There is a reset button in the back of your router, which will reset it to all default settings. Try this to get the router to work.
Also is it hard wired into another computer? Check it out that way. make sure the router is working.
good luck
Apr 13, 2010 | Linksys WRT54G2 Wireless Router
Router stopped working
check the power adopter and and also check your router's power led is glowing or not, if both are ok then need to check your internet service provider about internet connection.
Mar 04, 2010 | Dynex Enhanced-G Wireless Broadband Router
Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works...
Dell Inspiron 1525 PC Notebook Hi,\r\nAt my dell 1525 the battery... Answer Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell... (More) Hi, At my dell 1525 the battery status led flashes 4x orange folowed by a blue flash a.s.o. The dell manual identifies the battery as the cause. But, except for this optical signalisation, the laptop works well, the battery is charging, the AC adaptor is working properly. What is happening? Stefan
Feb 19, 2010 | Dell Inspiron 1525 Notebook
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
Have Linksys WRT54G2. All port led's are lit and
How is your router connected? If you have all port lights lit, either green or orange, and nothing connects seeing the Internet, are your problems with wireless access? Is the Wireless set correctly, by going to http://192.168.1.1 and logging in to the router? Make sure the SSID (network name) and other security measures are set correctly ... I prefer WPA-PSK[TKIP] for its simplicity. You will need the passcode you choose to log in with wireless devices.
Nov 11, 2009 | Linksys Wireless-G WRT54G Router
I have a Belkin 8623-4 and the "wireless" and modem icon flash orange. The internet icon does not light. Solve this
Are you using dsl or cablemodem?
If the internet led does not come on, then your router is not getting any communication from your dsl or cable modem. try reseating the connections and reboot each device.
Sep 20, 2009 | Belkin (F5D8231-4) Wireless Router...
My Acer netbook will only keep an internet connect when plugged in.
This netbook has a little orange led that blinks to let you know that the wireless is turned on. Then you know you can connect to wireless networks. Take a look at the photo here:
www.geekzone.co.nz/images/news/AcerAspireOne.jpg
To the right of the touchpad, at the front edge of the palmrest (closest to you) you will see a small silvery stripe. This is where the wireless led is.
First, look and see that the little orange led is blinking. If not, slide the little switch right beside it to turn on the wireless (you should see 'wireless lan enabled' in large green print) If you can't seem to get the orange led to blink by doing this, check device manager and check that the wireless card is enabled. If it has a red X on it, right-click on it and left click enable.
If the led is blinking, but you still can't connect to wireless, see if you can connect to another wireless access point other than your own.
Let me know if this helps or not :)
Aug 17, 2009 | Acer AOA150-1690 Aspire Notebook
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Compaq Presario Notebook Logo
513 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
