Question about Smeg FA561X Side by Side Refrigerator
Ice cube lock unlock - Smeg FA561X Side by Side Refrigerator
How to unlock a Scotsman ice machine code L board lock?
Push and hold in the on button for 3 seconds keep holding then press and release the off twice. it will unlock the controller
Aug 26, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How to unlock a scotsman ice machine code L board lock
Turn off machine. turn back on. what other code is it giving something is locking the board out.
Oct 02, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
My power locks will only unlock with the exception of the rear switch. Can you tell me the location of the lock relay so I can check it.
  • Aux Relay Box #4 is in the rear driver's side removable panel with the tire jack. This Relay box holds the Door Lock / Unlock relays (ice cube type). It also holds the Driver Door Unlock Relay and the ACC Lights Relay (rectangular relays).
  • Nov 21, 2010 | 1999 Ford Explorer
    Ice maker will only make crushed ice and no cubes, what could be the problem
    Open the freezer door.
    Pull the ice bin forward about 3 inches.
    Push the ice bin to the rear of the freezer until it seats and locks in place.
    Then try to dispense cubes.
    The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
    Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
    How do I unlock the ice-maker panel?
    Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
    Jun 28, 2010 | Bosch Evolution 800 B20CS80SNS Stainless...
    Cubed Ice selected, crushed ice comes out
    ice maker works. water thru the door works. lock works. light works, alarm works.
    when i try to get crushed, ice cubes or quick ice.
    nothing happens
    Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Admiral Fridge Freezer
    We had thought this was a free service...??? Yes, we fixed it ourselves, after trial and error. We pulled out the ice bin and there is an arm that is moves back and forth beside it. It had frozen up. That is the ice crusher. Thaw it out and it is fixed. By the way, the above posting was not by us--ours stated that our ice crusher did not crush ice anymore. Instead, cubes came out...
    Jul 12, 2008 | Admiral 26 cu. ft. Side-By-Side...
    Ice maker not getting water after changing filter
    Check the following:
     Is the freezer door closed completely?
     Is the ice storage bin installed correctly?
     Is there ice in the storage bin?
     Has the ice frozen in the storage bin?
     Is ice stuck in the delivery chute?
     Has the wrong ice been added to the storage bin? Use only
    cubes produced by the current ice maker.
     Has the ice melted around the auger (metal spiral) in the
    ice bucket?
    Dump the ice cubes and clean the ice storage
    bin.
     Is the ice dispenser stalling while dispensing “crushed”
    ice?
    Change the ice button from “crushed” to “cubed.” If
    cubed ice dispenses correctly, depress the button for
    “crushed” ice and begin dispensing again.
     Has the dispenser arm been held in too long? Ice will stop
    dispensing when the arm is held in too long. Wait 3 minutes
    for dispenser motor to reset before using again.
    The ON/OFF switch is located on the top right side of the freezer
    compartment.
    To turn the ice maker on, slide the control to the ON (left) position.
    To manually turn the ice maker off, slide the control to the OFF
    (right) position.
    NOTE: Your ice maker has an automatic shutoff. The ice maker
    sensors will automatically stop ice production, but the control will
    remain in the ON (left) position
    REMEMBER:
     Allow 24 hours to produce the first batch of ice. Discard the
    first three batches of ice produced.
     The quality of your ice will be only as good as the quality of the
    water supplied to your ice maker. Avoid connecting the ice
    maker to a softened water supply. Water softener chemicals
    (such as salt) can damage parts of the ice maker and lead to
    poor quality ice. If a softened water supply cannot be avoided,
    make sure the water softener is operating properly and is well
    maintained
    The Dispenser Lock (on some models)
    Your dispenser can be turned off for easy cleaning or to prevent
    unintentional dispensing by small children and pets.
    NOTE: The lock feature does not shut off power to the product, to
    the ice maker, or to the dispenser light. It simply deactivates the
    dispenser levers. The ice and water dispensers will not work.
    Style 1: Press the LOCK BUTTON to lock the dispenser. Press the
    UNLOCK button to unlock the dispenser.
    Style 2: Press and hold the LOCK OUT button to lock the
    dispenser. Press and hold the LOCK OUT button a second time to
    http://www.ajmadison.com/ajmadison/itemdocs/2261717.pdf
    May 15, 2008 | Whirlpool GS5SHAXN Side by Side...
    Smeg FA561X Side by Side Refrigerator Logo
    61 people viewed this question
    Top Smeg Refrigerators Experts
    John Tripp
    John Tripp
    Michael Galve
    Michael Galve
    ashburton
    Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
