Question about Cisco Computers & Internet
Default login password - Cisco Computers & Internet
4 Suggested Answers
tom19511
  • 1601 Answers
SOURCE: regarding default loacalhost login name and password
 use the default Login name “admin”, and no password
Posted on Oct 22, 2007
SOURCE: DI-624 can't login as admin
I was ready to give it up and pitch the thing, but I found this on another board and it worked:
login - admin
password - password (not blank)
Posted on Jun 08, 2009
virtualhost
  • 2185 Answers
SOURCE: default login & password
You can try the following passwords in this link:
http://cirt.net/passwords?vendor=SMC
Posted on Aug 03, 2009
Login and password
The default login and password should be in your user manual. If you cannot find the manual, check the MFG website or Google your brand and default login. If you cannot access because of your own password and login, reset the router (manual or website should walk you through this) at which point it should reset login and password to default.
Nov 13, 2013 | Computers & Internet
Tip
Forgot my password.
If you ever forget your password to your router you can look up the default password online.
Most default passwords for linksys is: login=blank password=admin
Default passwords for belkin is: blank
Default passwords for netgear: login=admin password=password
Default passwords for d-link: login=admin password=1234 or password.
if none of the passwords work then you can reset the router to factory defaults by holding the reset button in with a paperclip for 30 seconds while powered on. This will erase any customized settings and apply the factory default settings. If the password doesn't work please check with your device manual.
on Feb 23, 2012 | Linksys Computers & Internet
How can we open the router configuration without password.......& usernane
Dear Friend,
If you don't have change your password from factory defaults then look into manual for user name and password...
If you have change your password then, Sorry you have to reset your router. this will delete all your configuration but will set your login id and password to factory defaults... ( there is no other way)
Please rate the answer
Jun 08, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Change router settings
hi,
in the browser type 192.168.1.1 and insert your login and password. if you have not change the login name and password then visit to your manufacturer site for default login name and password.... Usualy default login name and password is "admin".....This page will lead you to the router settings....
Hope this has helped you..
Thanks...
May 15, 2010 | 3Com OfficeConnect Wireless Router
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
Aug 03, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
Will not accept login and password.
Duh... when restarting the computer... before it got to the login and password acceptance fields, I hit F2 (setup). I was able to default password settings there!
Mar 23, 2009 | Dell OptiPlex GX260 PC Desktop
Regarding default loacalhost login name and password
Oct 20, 2007 | MandrakeSoft MandrakeMove 9.2 (Trial)...
Password problem
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." Once you are past the login screen, you are able to reconfigure the LinkSys router
Aug 10, 2007 | Linksys NSS4000
What is the default user name and password to login the Prestige via the browser?
To restrict only the adminstrator can configure the router, there is a login procedure prompted for asking User Name and Password. The default User Name is 'admin' and the default password is the default SMT password, '1234'.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Computers & Internet Logo
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
