Question about Fisher Price Fisher Power wheels Cadillac Escalade EXT
Rear speakers in power wheels not working - Fisher Price Fisher Power wheels Cadillac Escalade EXT
No sound but radio has power
Check to see if your speaker wires are cut from the radio to the speakers. Not all of the speakers will stop working at the same time. On my 2001 expedition, the front worked but not the doors or rear. I found a cut speaker wire that is located behind the windshield trim above the stearing wheel where someone had installed an air freshener with a screw
Mar 14, 2015 | 1998 Ford Expedition
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
Connector Part Information
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
42.1i passenger side rear has power but sound is very quiet and tinny. all 3 other speakers work fine.
It sounds like the woofer part of the speaker is bad, while the tweeter is still good. You are going to have to replace the speaker. Speakers are generally sold in pairs, so it would be best to replace both rear speakers at the same time.
Jul 18, 2012 | Infinity KAPPA 42.1I Car Component System
Rear cluch not working
Depends on what model and components you have:
ENGINE TORQUE DISTRIBUTION – DIRECTING THE FLOW OF POWER
In an all-wheel-drive vehicle, engine power can be directed to all four wheels. Subaru Symmetrical AWD differs slightly from model to model in how it directs power to the wheels, depending on its transmission.
MODELS WITH FIVE-SPEED MANUAL TRANSMISSION – CONTINUOUS ALL-WHEEL DRIVE: A viscous-type locking center differential and limited-slip rear differential help distribute torque – normally configured at a 50/50 split front to rear. If wheel speed differs between front and rear axles, the center and/or rear differentials lock up to help distribute power to the wheels with the most traction.
MODELS WITH FOUR-SPEED AUTOMATIC TRANSMISSIONS – ACTIVE ALL-WHEEL DRIVE: An electronically controlled variable transfer clutch and limited-slip rear differential distribute power to where traction is needed. Sensors monitor parameters such as wheel slippage, throttle position, and braking to help determine torque distribution and direct it to the wheels with optimum traction.
MODELS WITH FIVE-SPEED AUTOMATIC TRANSMISSION – VARIABLE TORQUE DISTRIBUTION ALL-WHEEL DRIVE: As with Active All-Wheel Drive, an electronically controlled variable transfer clutch distributes power, but through a planetary-type center differential and a viscous-type limited-slip rear differential. Torque distribution is normally configured at a performance-oriented rear-wheel-biased 45/55 split front to rear. Sensors monitor the same parameters as for Active All-Wheel Drive.
WRX STI, WITH SIX-SPEED MANUAL TRANSMISSION – DRIVER CONTROLLED CENTER DIFFERENTIAL (DCCD) ALL-WHEEL DRIVE: The STI uses an electronically managed multi-plate transfer clutch and a mechanical limited-slip differential in conjunction with a planetary-gear-type center differential to control power distribution between the front and rear wheels. Featuring manual and three automatic modes, DCCD is normally configured at a 41/59 split front to rear. Sensors monitor parameters such as wheel slippage, steering angle, throttle position, and braking to help determine torque distribution and direct it to the wheels with optimum traction. DCCD also features a limited-slip helical front and Torsen® rear differential. ... }
And what are the symptoms? How do you know the coupling to the rear is not working?
Jun 05, 2010 | 1995 Subaru Legacy
May have wrong audio system
The Azera Limited adds those items, plus a larger engine, power-folding mirrors, a power rear sunshade and a 10-speaker Infinity stereo. The Limited Ultimate Package adds a power-adjustable steering column and pedals, driver memory functions, wood steering wheel and door pulls, rain-sensing wipers and a 12-speaker Logic 7 surround-sound system with an in-dash six-CD changer.
http://www.zzounds.com/item--APLLOGPRO
Mar 25, 2010 | 2009 Hyundai Azera
I am putting in a cd player and i don't understand why it won't get power. i hooked it up staight to battery and it works just don't know which wire is power from the fuse block
1995 Jeep Grand Cherokee Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red/White
Radio Switched 12V+ Wire: Red/Gray
Radio Ground Wire: Black
Radio Illumination Wire: Blue/Red
Radio Dimmer Wire: Orange
Radio Power Antenna Trigger Wire: Green/Red
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Green
Left Front Speaker Wire (-): Brown/Red
Right Front Speaker Wire (+): Purple/Yellow
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6 1/2′
Rear Speakers Location: Rear Doors
Left Rear Speaker Wire (+): Brown/Yellow
Left Rear Speaker Wire (-): Brown/Light Blue
Right Rear Speaker Wire (+): Blue/White
Right Rear Speaker Wire (-): Blue/Pink
Oct 01, 2009 | 1995 Jeep Cherokee
Radio harness diagram for 95 chevy tahoe....rear
check wiring on passengers side near the rear hatch speaker, the rear door speakers are run through them also. i had the same problem and it was a unplugged connector at that location
Sep 17, 2009 | 1995 Chevrolet Tahoe
Speakers are not working with new head unit
There is a factory amp in this vehicle. It is located in the rear behind the plastic wheel panel under the rear passanger window.
May 21, 2009 | 2003 Ford Explorer
Rear speaker connection issue
OK, the fix for the missing rear speaker sound on the DELL WL6000 5.1 Surround Speaker System is relatively simple, just 7 simple steps (Verified by Dell at http://support2.jp.dell.com/docs/acc/P121646/multlang/srg/DAO/srg_dao.pdf..
First, power down everything. Second, disconnect the rear speaker and subwoofer from the power source and wait about 5 minutes. Third, be sure the power switch is off on subwoofer and the center speaker. Fourth, plug in the power for the subwoofer but DO NOT turn on the power yet. Fifth, plug in the rear speaker power cord. Sixth, turn on the swtich on the subwoofer (this is the start of the resync mode). Seventh, turn on the center speaker power and the system will change the rear speaker system LED from flashing blue to solid blue in 5-8 seconds. The surround system is functioning again. You may test this under sound in the Control Panel but I would prefer to use a modern music CD that has Dolby Digital Support for 5.1 sound or better. YOU WILL HEAR INSTANTLY THE SOUND DIFFERENCE WHEN THE REAR SPEAKERS ARE CONNECTED.
Nov 10, 2007 | Dell WL6000 Computer Speakers
Fisher Price Fisher Power wheels Cadillac Escalade EXT Logo
174 people viewed this question
Top Fisher Price Toys Experts
Bill Boyd
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
