Question about Craftsman 25cc Gas Line Trimmer
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
I have a craftsman gas convertable 25cc weedwacker, model number 358-795590. It's starts just fine, runs for a few seconds and dies. I try holding in the throttle but that doesn't help. The primer seems fine. Suggestions?
  • Anonymous May 26, 2009
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
I HAVE A CRAFTSMAN WEED EATER 17/25CC WHEN I START IT AND TRY TO ACCELERATE IT DIES OUT .WHAT SHOULD I LOOK FOR ?
Posted on Jul 13, 2012
Buy a new one and return the old one..... problem fixed!!!
Posted on Jun 14, 2010
Check this page out, i have a small engine scooter by LIFAN and what the article said might help me.
http://www.fixya.com/support/t872637-briggs_stratton_engine_stay_running
Posted on May 18, 2009
Sears & Craftsman 25cc Weedeater brand new starts but will not stay running?
Try leaving the chokey partially engaged. Operate it this way for a few minutes until the engine is thoroughly heated then move to the run position. If this does not work return it.
Aug 13, 2014 | Sears Craftsman Convertible 25cc 2 Cycle...
I installed a new carburator on a craftsman 25cc weedwacker model 358796600 and it wont't start
You might want to Google the model number for a service manual or contact a sears service parts center for help.
Jun 17, 2012 | Craftsman 25cc Gas Line Trimmer
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Apr 07, 2011 | Craftsman Convertible 25cc. Gas Line...
Machine will start but won't stay running. give some gas and it runs for a couple of seconds and then dies. i did replace the spark plug but it is doing the same thing. it is a 25cc craftsman weedwacker...
I had a similar problem and it was simple to fix. I hope yours is the same. The line going into the gas tank is not far enough down in the tank.Once you prime it with the primer bulb , it will run till that gas is gone. No fuel from the tank is getting to the carburetor. If you've replaced the fuel lines recently, this may be your problem. If not, try cleaning the fuel tank and the carburetor. Hope this helps.
Sep 08, 2010 | Craftsman 25cc Gas Line Trimmer
Where can I find parts for a 25cc Craftsman Weedwacker engine
get your craftsman parts from Sears [1-800-4myhome]. be sure to have your FULL model number available
Sep 07, 2009 | Craftsman 25cc Gas Line Trimmer
Crapy weedwacker
go to sears.com click on the parts direct tab and enter the model number and order a new cap from them.
Aug 04, 2009 | Craftsman Convertible 25cc. Gas Line...
The weedwacker dies when I squeeze the throttle trigger
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
Jim
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
8,874 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
