Question about Miele Novotronic W1918A Front Load Washer
Miele novotronic W986 leaking water from underneath
Machine is leaking water from under so that there is water under the machine. Looks like the water is coming from the front but we cannot locate where. Also, we can't open the Little hatch to the left on the machine. It is a Square lid but how do we open it?
  • 70 Answers
SOURCE: Miele novotronic w820
i havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
Posted on Jul 26, 2008
  • 106 Answers
SOURCE: Miele Novotronic Premier Plus - no water into the machine
Plug off the wall. Unscrew the hoses that bring water to the machine, check the fine meshes on hose as well as machine, clean out well with tooth brush (not yours), see that pressure is good in your wall socket. Refit carefully, check for leaks.
Posted on Feb 27, 2009
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
  • 82 Answers
SOURCE: water leaking
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it
ie a crack in the plastic allowing water to escape
Posted on Jan 16, 2010
  • 177 Answers
SOURCE: How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Posted on Jan 18, 2010
Testimonial: "Thanx for the help. I managed to get my first wash very successfully. "
Water leak on spin cycle no warning lights on
If there's water underneath the machine, check drainage pump. Most likely gasket or simmering. If necessary replace pump (about $45,00).
Apr 25, 2015 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic w1930 leaking lower left
Good morning
From what you described it could be that your drain hose is cracked since it is bending on the inside of the machine when you push it in after draining the water.An other possibility could be a clamp failing or th connector on the drain pump that is cracked.
To solve the problem would be to dissmantel the machine to assess the machine on the in side for any devects.
One other thing to check for is the plug on the end of the drain hose,is it a tight fit because it it could be leaking at the plug.
If you think it is not tight enough use a cable tie to tighten it and see if the leak will stop.
Dec 05, 2013 | Miele Novotronic W1930 Top Load Washer
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Water leak
first you should open the unit and find out if the leak is coming from a hose or the pump or maybe a crack in the tub
Jul 25, 2010 | Miele Novotronic W1918A Front Load Washer
Water leaking
Jan 16, 2010 | Miele Novotronic W1918A Front Load Washer
Miele novotronic w864 water leak
it maybe choked out. just lay it down and see if there is any thing or thrust a heavy shower of water in the pipe.
Aug 07, 2009 | Washing Machines
Feb 26, 2009 | Miele Novotronic Premier 500 Front Load...
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Aug 06, 2008 | Miele Novotronic Premier 500 Front Load...
Wate rleak Miele premier 300
I have exactly the same problem with my new Miele washer dryer - and my kitchen is soaking wet. Have you found a solution ?
Jul 28, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W1918A Front Load Washer Logo
62 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
