Question about Goldstar Microwave Ovens
Goldstar GMK 49 won't work with mac - Goldstar Microwave Ovens
Seeking to purchase Goldstar MV-1304W/B - need microwaave 24" or less with vent for over stove. Is it still available or is there another model that will work?
There may be a General Electric model that is essentially the same with a different label. Other brands will work, although you will probably have to change the mounting bracket. They are not as likely to have problems with the magnetron's magnet losing field strength, as was the case with some Goldstar/GE wall-mount units from the 1990's.
Apr 14, 2014 | Goldstar Microwave Ovens
Fan won't turn off
One or two of the door switches has failed and must be replaced, due to food partical build up.
Mar 15, 2012 | Goldstar Microwave Ovens
I have a Goldstar Microwave: Goldstar Model # MV1502W/01 Serial # 703TAHQO1537 Manufactured March 2007 The microwave won't power on at all. what troubleshooting can I do?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 26, 2011 | Goldstar MV-1501 Microwave Oven
Turn table won,t turn
check and see if the turn plate is on correctly
Feb 25, 2010 | Goldstar MA-780M Microwave Oven
My goldstar mv1501B won't heat anything. What' wrong?
everything works except the heating system what shell i do?
Mar 25, 2009 | Goldstar MV-1501 Microwave Oven
Don`t cook
try opening the case and checking the internal fuses. these normally cause the problem
Feb 01, 2009 | Goldstar Over-the-Range Microwave
Microwave oven does not work
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
You can get warranty info & find a local authorized servicer.
Jan 15, 2009 | Goldstar MV-1615 Microwave Oven
Goldstar Convection Micro/Grill 800W
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 25, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar 1500m
The most common causes for this (in order) are a defective door switch, door switch mount, or a bad connection or relay on the control panel. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
May 25, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
47 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
