Question about TTX Tech Sony Playstation 3 PS3 Wireless Controller /
Usb connection it will not work with the usb cord
My Singer Futura CE 200 embroidery machine will not work. The part of the USB cord that attached to the actual machine is not working. When connected, the computer says it is not connected. I know it is...
USB ports are known to fail- try connecting another device to your computer to see if it is recognized and is functional.
If so, then the port of of the Singer has failed.
Oct 14, 2014 | Sewing Machines
Why won't mu usb cord work for downloading pictures
Here is one possible solution. Some devices require that you use the USB cable that came with the device. Other USB cords won't work. This happened on a Nexus tablet I bought recently. When I tried to charge it with another USB cord, nothing happened. I had to use the exact USB cord that came with the tablet, even though both cords looked identical.
Aug 14, 2014 | Cameras
The port to which the printer is connected is not supported. Check the port
I'm assuming you are using a USB connection, not a Ethernet connection.
Try a different USB port (preferably in the REAR of the computer, not the front). It's not unusual to have 1 or 2 poorly-performing (low power) ports on a PC; some printers don't like those.
If you have a really old computer, it may have ancient USB type "1" (slow) ports instead of the newer 2.0 or 3.0 USB type. Some printers don't like old USB 1 ports, but it is not supposed to matter.
If all else fails, try another USB cord, or a shorter one. Some printers don't work well with cords longer than 4 feet, and USB cords can go bad.
Or, try the printer on another computer. If the same USB cord works fine there, YOUR computer has the problem (probably a USB port or USB driver issue).
Are you having issues with other USB devices? If so, it may be a Windows driver issue.
Good luck. If no help, post your exact printer model # here, or try contacting Lexmark.com support
Dec 02, 2013 | Lexmark All-in-One Printer with PictBridge
I'm trying to sync an apple ipod shuffle 4th generation to my windows xp pc. The famous USB device not recognized thing pops up. What do i need to do so i can use and sync my ipod.
Shutdown Windows.
Turn the computer off.
Unplug the AC power cord.
Reconnect the AC power cord.
Restart the PC.
This will eliminate many "intermittent" problems.
Now, connect some other USB device (mouse? keyboard? memory-stick?) into the USB port, to confirm that the USB port is working, at least for some USB device.
Now, connect the iPod to one of the USB ports.
If it is not recognized, connect the iPod to a different USB port.
This should work.
Jun 01, 2011 | Computers & Internet
What does usb device not recognized ?
The best you can do is,
Turn off the PC/Laptop
Disconnect the USB cable from Camera to pc/laptop
Disconnect the power cord connecting the pc/laptop and the wall jack or surge protector
Disconnect the power cord connecting the camera to wall jack or surge protector
wait for 5-10 mins
Connect the power cord of PC/laptop and turn on the pc/laptop and login to your PC
Connect the power cord of Camera to wall jack or surge protector
Connect the usb cable or camera to PC/laptop
It should get recognised and work fine.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 20, 2011 | HP Photosmart R847 Digital Camera
Sony NEX-3 - I can't seem to connect to my computer with USB connection. Camera is on and cord for usb is attached
Hi there, If you haven't already done so... Try connecting to a different USB port, or on a different computer. I noticed on my brothers computer, that when I use one USB port - doesn't work, but the other one does (probably something faulty inside on one of them). Also can try connecting using another different cord...
Hope you can get connected... ****.
Nov 26, 2010 | Sony Cameras
Usb thing popped out
this would be alot easier on a desk top but something like this happened to me awhile ago and what i did was open the compuer and find where the cord connecting the usb port is. Your cord most likely got disconnected and you need to connect it again. That should fix it.
Mar 10, 2010 | Logitech ClearChat Pro USB Headset
USB cord
try out the normal usb exten cord which is used for I-Pods, this will work out
Mar 30, 2008 | Panasonic Lumix DMC-FX8 Digital Camera
USB connection cord
Yes, the CB-USB4 cable (packaged with the camera) is required for downloading images from the camera. The stock number for a replacement cable is 200776
Sep 01, 2005 | Olympus Stylus 410 / ? 410 Digital Camera
TTX Tech Sony Playstation 3 PS3 Wireless Controller / Logo
Top TTX Tech Video Game Consoles & Games Experts
James Wishart
Are you a TTX Tech Video Game Console and Game Expert? Answer questions, earn points and help others
