Question about Speed Ceiling Fan 3-speed Switch By Westinghouse 77021
Home blt.62 I am installing ceiling fan. when installed,fan works
The lower lights do not. backing doun step by step,I recieved a shock.using tester, i discovered the systm is hot even when the wall switch is turned to minimum and off.(switch is a reostat). checking further with meter, i still have 125 v across. by checking white to the metal box,i still have 125v.i have removed the fan,pulled all wireing out found no wires touching metal. however,haveing worked on large boat wireing, i removed all old tape, and recovered it with heat shrink. I have a two wire system,with a hot box? _ and lights not working. Ihave installed 3 similar fans over the past 2yrs in this house. HELP.
  • 44 Answers
You need to contact an electrician and have them evaluate your home's wiring in its entirety. They should also inspect the other work you've done. The wiring in your house is NOT to be installed in the same manner as the wiring in a boat or RV. You don't use heat shrink in stead of UL-approved splices (most commonly wire nuts in a residential application) and black tape. This is exactly why so many places require that any work on an electrical system be performed by a licensed electrician.
It sounds like somewhere in your house, you have a short to ground and your ground rod isn't diverting this voltage to ground. If it were functioning correctly, it would most likely trip the breaker on the affected circuit. This is not something to take lightly. Your safety and that of your family is at stake here.
Posted on May 24, 2009
How to install Hampton bay fan #CF 004-52 on a slanted ceiling
I'm an electrician and can help you with your question.
Most (if not all ceiling fans) are designed to hang from most ceilings - flat or angled. This is done through the use of a molded plastic ball secured to the downrod of the fan assembly, that will allow the fan to "self-level" in the hanger
A special "hoop like" hanger is secured to the fan rated electrical box that allows the fan to hang straight down - providing that your ceiling isn't at a real freakish angle - all by itself. The only other thing to watch for is the blades. This is especially true if the new fan has larger blades or a shorter downrod than the old fan. Make sure that the fan blades will clear the ceiling (and enything else for that matter) when running. Otherwise, you will need to use a longer downrod to allow the fan to hang a little lower. Make sure it is not too low to prevent it from striking people walking below it.
Review the installation manual and check out the support "hoop" for the electrical box and the downrod with the plastic ball on the end (may require assembly of the ball to the downrod). You can install the support hoop and hang the downrod to make sure you understand how it works without assembling the rest of the fan.
If you have any problems, you should contact Home Depot (Hampton Bay is a Home Depot house brand) for support.
Mar 28, 2013 | Hampton Bay 04345 Cruiser Ceiling Fan
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
I just installed a 52"
yes this is because the dimer is giving the light less power.you just need to change the switch to a single switch then your dimer will work right all the time. good luck
Aug 12, 2011 | Hunter 52" Ceiling Fan With Light And...
My hunter fan is not working. the remote has a new battery however it will not turn the fan on or off and it will not turn the light on or off. the chain on the fan will only work the light. the fan...
It sounds that fan use to work and lights and you did correct thing by changing battery. I've had this problem and it just needs the reciever replaced. Reciever is located at electrical connection in ceiling. Just buy a new universal wireless remote and reciever at any home depot. if dont fill safe doing this task should call an electician to do job or someone with electrical skills.
Aug 13, 2010 | Hunter Ceiling Fan Light Remote Control
I have a Hampton Bay ceil fan model # AC-552 "NN" and the serial # 000371. We had lost power in our neiborhood a while back and was use the generator and when the power came back on our fan didn't work....
Hampton Bay is an exclusive brand of Home Depot. They would be the ones to help you with that. BUT .. from my experience I would say that the cost and trouble of getting and replacing the motor in that fan would be easilly rivalled by the cost and ease of buying and installing a new fan all together.
Please Vote !!
Jun 02, 2010 | Hampton Bay 52 In. White Redington...
Im installing a hunter remote control receiver in the ceiling mount. I have a red, black, white and ground wire from the ceiling. Which wire on the reciever do I connect the red wire to?
The red wire in the ceiling is probably used in a shared neutral circuit and not needed for the fan. If it's not capped off already, it should be.
Just use black, white and ground from the ceiling.
Charlie
Aug 16, 2009 | Hunter 52" Ceiling Fan With Light And...
My home is pre wired for a ceiling fan in the master bedroom. There are two light switches that control the pre installed wires. One for the light on the fan and one for the fan. There are four wires
The usual wiruing for these fan/light circuits is that the black wire on one switch is for the fan and the red on the other switch is for the light. If you are using a remote set up for both fan and light, then hook the remote wires to the black and white wires in the ceiling, You can cap off the red wire in the ceiling as this will not be used.
Apr 24, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Bottom lights do not turn off
If you have a remote for the fan and light, then it makes sense that only one wall switch operates as a master switch. Then as far as why the remote doesn't operate the lower light, the question I would have is whether the remote you have for the new fan came with it or not? If the remote you have has a button for the upper light and a button for the lower light, then you need to make sure that the reciever in the fan has wires for both lights. On the receiver there should be a black and white for the power and neutral coming from the switch. Then there will be a white wire for the neutral to the fan, a black wire going to the fan, and probably a blue wire for one of the lights. If there is another wire on that reciever (it may be orange or some other color) that would be the wire for the other light. That would be simple... four wires from the fan to four wires coming off the reciever. What you might have is four wires coming from the fan, and three wires (other than the black and white which connect to the wires from the switch) coming from your reciever. The way around that is to connect the two lighting wires from the fan to the one lighting wire from the reciever. Then when you press one of the light buttons on the remote, the upper and lower lights will always come on together. The other possibility is that there is a problem with the lower light kit itself. I would first check the wiring inside the canopy of the fan where the receiver most likely is.
Jan 24, 2009 | Hampton Bay 52 In. White Redington...
Fixing Ceiling Fan
An easy-to-install ceiling fan can make a real difference in your home's climate - both cooling and heating - at a far lower cost and operating expense than almost any other item.
The installation begins with choosing where the fan should be located. In almost all homes, the fan is installed in the center of the room, replacing a central light fixture. This spot provides a smooth air flow to most of the room. Since a fan draws about the same power as a ceiling fixture, the electrical circuit shouldn't be overloaded. But if your fan includes lights, be sure the circuit it's on has enough extra capacity to handle the load. If not, you must run a new circuit with a new circuit breaker from the house main service panel or subpanel to the fan. If there is no central light fixture, you'll have to create a place to hang the ceiling fan. Then, you'll need to bring electrical power to it. You can tap into an existing circuit to do this.
Sep 25, 2008 | Dryers
Open Questions:
See all Speed Ceiling Fan 3-speed Switch By Westinghouse Questions
Speed Ceiling Fan 3-speed Switch By Westinghouse 77021 Logo
251 people viewed this question
Top Speed Electrical Supplies Experts
epangan29
 Generator Guru...
Generator Guru...
Are you a Speed Electrical Supply Expert? Answer questions, earn points and help others
