Question about Karcher 1750 psi Electric Pressure Washer
I have a Kodiak electric power washer that has served me well over the past few years. It was working at the start of this season and suddenly it has stopped. Is it an easy fix or should I file this under G for garbage. Thanks
    Sniper:
  • 61 Answers
It really depends on what has caused it to stop. DO you know if it is getting any power. Checked fuses in plug etc?
Posted on May 17, 2009
98 lexus es300 a/c fuse #24 keeps blowing
This fuse may serve the compressor clutch. Were you using the AC at the time? If yes, you may need to replace the compressor clutch. There are also a few other circuits on this fuse. See diagrams at the link below.
Repair Guides Overall Electrical Wiring Diagram 1998 Overall Electrical...
Aug 15, 2017 | Lexus ES 300 Cars & Trucks
Tip
How to end Compaq CQ70 misery
I have owned a CQ70 for 2 years 2 months. Before I reveal my tips, here's my experience:
On purchase:
- quick start guide doesn't even show keys and switches, how to use camera, etc
- no software or manual supplied, only useless safety guide CD
- request for info to Compaq online: they returned a form to let them know how well they had served me when they hadn't served me at all
- subsequent requests unanswered
- complaint to www2.hp.com returned a worm called HTML-script-inf
First year:
- keyboard failed after 2 months; replaced under warranty
- screen failed after just under a year; replaced under warranty
- sound regularly disappears; have to reboot
- carrying bag burst within 6 months
- SD card reader worked intermittently for a few months, then not at all
Second year:
- I accidentally discovered the touchpad disable button; it doesn't work
- battery expired after 18 months
- replacement screen started to fail after 18 months
Now:
- replacement screen failed completely after 2 years 2 months
- I get electric shocks off the left side
- it generates constant flow of "Enter" commands; keyboard, mouse, USB ports cleaned to no avail; clears on reboot for a few hours (no viruses / worms - I regularly check)
- the HDD will not start spinning on mains power; I have to remove power cord and start on battery only, then replace power cord
Tip #1: I understand from a friend who works for HP that the good components go into the HP series and all the s*** into the Compaq series, so DON'T BUY COMPAQ.
Tip #2: If you have already bought one, put it in the bin or use it for landfill
Tip #3: If you want a reliable computer that will last for years, buy a cheap and cheerful Taiwanese no-brand. We've got two - they're great.
on Jul 05, 2011 | HP Compaq Presario CQ70-120US Laptop
I have a Speck Pump, model E71, only a year old. It suddenly stopped working - it was fine at the start of the season. The problem is that it just hums when turned on.
Since it hums it has power. I believe there is a start capacitor on it, that or the start switch may have failed.
Speck Pumps Pool Pump Parts
usa speck pumps com
have Speck Pump model E71 only year old It suddenly stopped working it was...
Speck Pumps Pool Products Inc
Jul 02, 2016 | Speck Pumps Pool & Spa
Kodiak manual
www.ppe-pressure-washer-parts.com/kodiak-pressure-washer-parts
NOTE: We are not KODIAK or affiliated with them. We did not sell these Pressure Washersbut do offer some parts that will fit them.
As close as I could fine. A hard one.
May 20, 2014 | Garden
Where is the battery located on a yamaha kodiak
Much the same for most models with a few minor differences depending on the year and model of bike. Look under your seat.
Jan 20, 2013 | Yamaha Kodiak 450 A 4x4 03 Airbox Air Box
Loseing ignition modules
i would start by keeping an eye on the volt meter to make sure its not over charging at times, and the other thing is to make sure theres a good ground from the engine to the frame and also from the battery to frame, also you may what to try a ac delco module if not already using one,,well hope this helps and good luck.
May 11, 2010 | 1983 Chevrolet Blazer
A e g washing machine
If the washer doesn't operate or make any noise when set on any cycle, or if it stops suddenly when it should continue onto the next cycle, it may not be receiving electrical power or, if the motor stopped mid-cycle, the machine's overload protector may have tripped. In this case, take out some of the articles to reduce the load and let the protector reset itself, then restart. Otherwise:
1) Be sure it is plugged in and turned on. If necessary, check the receptacle it's plugged into for power, using a working lamp, appliance, or voltage tester. Be sure the washer lid is closed completely.
2) If the receptacle seems dead, check the circuit breaker or fuse that serves that circuit.
3) Unplug the washer and check the power cord. If necessary, replace the cord if you feel qualified.
4) Open the lid and check the lid switch and the tab on the lid that it pushes against. Press and release the switch: if it doesn't click when you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person.
5) If the washer still doesn't work, the controls may be faulty. Call a service person.
Feb 29, 2008 | Washing Machines
Karcher 1750 psi Electric Pressure Washer Logo
750 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
