Question about Gateway M520CS+ Notebook - Intel Celeron D 330 2.66ghz - 512MB - 15 XGA TFT - Intel Extreme 3D -... (2900678) PC Notebook
Power "On-Off" button seems to be malfunctioning. I want to take case apart to check it out. Need info on how to take it apart.
Power button
Tip on this unit is long triangle shape in the case. Could be possible that it broke but i don't think so think it might just be wore down. 710 ia an old unit an has been out for few years, so it seems likely that with the use you put it through it probably wore out. You can take the unit apart and check if you want depending on how comfortable you are with this type of work. If you need help or directions with how to take it apart let me know and i will post some instructions for you on how to do it.
Nov 26, 2013 | Rand Mcnally TND 710 GPS Receiver
5 beep error dell 5110 laptop when i press power
It seems like your ram has come up all you need to do first is to open your ram section and then take apart each ram module one by one to ensure which specific module is malfunctioning.
Nov 01, 2013 | Computers & Internet
I have a Motorola Talkabout from 1998 that has a talk button, a monitor button, and a power button. Whenever I press the talk button it just says the channel....but when I talk through my other walkie...
It seems a small hardware-problem, like a button is sticking, making a continues connection. If you are comfortable in hardware-modifications, try to open the casing of the malfunctioning walkie talkie. Do this carefully, not to damage it further.
When opened, check the 3 buttons to see any damage, or undesired connections (caused by extensive use or plain dirt).
Oct 14, 2013 | Radio Communications
Power button won't stay depressed
You have an on/off button malfunction...the insides of the button have come apart and you will need to replace that button...
heatman101
Dec 13, 2010 | Vacuums
My MSI Wind Laptop case came apart at the screen hinges
yes. you need a technicians or professional help on this... there might be problem on your unit.
May 10, 2010 | Computers & Internet
I actually have an HP Pavillion zd8000 where I need to install a new DVD "D" Drive. I have removed all of the screws, including the ones under the battery, by the Hard Drive, the back base of the monitor...
Generally, the optical drive can be removed without taking the casing apart, just one screw holds it in under the laptop. If yours is one of those that does need to come apart, you will need to make sure that the two screwsat the rear of the laptop are undone. When you take the bexel off where the power button is, there will be two more screws holding the hinge in, they need to come out too. Then you need to remove the LCD screen before the rest of the case will come apart.
Nov 22, 2009 | HP Pavilion dv9000z Notebook
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
Zoom H-4
Ask your dealer, the one you bought it from. They may suggest an easy fix or guide you best on how to get it repaired, or at the very least suggest a place near you to have it repaired. If your dealer doesn't know, ask any Zoom dealer for repair info. Meanwhile, I assume you've checked your battery compartment to make sure the terminal connections are not loose (and of course that you've tried new batteries - :) ). Also, check Menu>Battery to see if alkaline or nickel batteries is checked. Finally, try removing your SD card and re-inserting, (even re-formatting the card, perhaps, but trying merely re-inserting first). But make sure any songs/info on the card are backed up first, because you will lose info if re-formatting the card. (For that matter, you could try a new card.)
Sep 11, 2008 | Zoom H4 Handy Recorder
When I turned it on it shows a blinking screen reading Venus2 UT R10. and then 0=WINCE upgrade 1=GPS Tools 2=BT Tools etc. and none of the normal functions come up.
This happens when both the power and reset button are depressed. In my case the menu came up and the selection between items would loop. Pressing buttons did nothing. It wouldn't even allow me to select anything.
Solved the problem. It appears that the reset switch malfunctioned. I opened it up (hint: use a guitar pick to pry the edges apart) and removed the reset switch. If you don't like to solder you can gently pull the top off the micro switch and that will do it. Cleaned it with compressed air. .... Now all I need is new reset switch.
Jul 21, 2008 | Magellan GPS
Power on Problem!!
Did you plug the cables for the front devices and buttons into the motherboard at the right locations? Are the polarities correct on for your cables?
Jun 26, 2007 | XION Onyx (XON-301P) ATX Case
Computers & Internet Logo
53 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
