Question about Tricity Bendix 24 in. DH102 Free-standing Dishwasher
My Tricity Bendix won't work
The problem is as though it will not fill with water and not getting enough power. It seems to start, though much quieter, then does nothing. On a couple of cycles, the dial partially moves around yet the machine does nothing! The machine is a 5 year old DH 102.
Please help!
  • iancando Jul 18, 2008
    starts the emptying cycle when 1st switched on but does not fill. If you add the water manually the wash cycle is OK until it tries to fill for the rinse cycle. Have checked all the filters and water level switches.
    Its a CDW 087 model approx 7 years old
Check out the water inlet solenoid valve if this is clicking then it is probably the water level pressure switch which appears to be controling the flow of water mechanicaly dependent on whether the water is high enough in the machine and therefore giving enough pressure to close the switch .This may be stuck closed.
Posted on Apr 30, 2008
2001 dodge neon, it was raining and I was driving along fine when suddenly the car seemed to have no power. all the electrical stuff was still working lights, radio, etc. but it wasn't running any more. I...
I would start by checking main fuses under the hood. water could have cause a short also check battery cables to see if they are heavy enough to carry the amp load needed to start the car. factory cables are not heavy enough after a few years.
Aug 07, 2013 | 2001 Dodge Neon
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
Water not filling.
r u using auto fill mode?if u r then try selecting high medium or low. check water pressure coming out of inlet hose, could b faulty valve not letting enough pressure thru.please reply if u need more help
Mar 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
The sound was as though one of the pulleys was worn. I replaced the tensioner, the pulley, the water pump (which is on the drivers side, the engine is traverse) it is the northstar 32v. I cannot detect...
Noise you are hearing may be the front bearing in the alternator. When you first start the car the alternator is working harder to replace power you used to run the starter. You can verify the noise source by putting a long bar against the alternator and holding the other end on your ear. be careful not to get the bar into the belt or it can do damage.
Sep 19, 2009 | Cadillac Eldorado Cars & Trucks
The start timer control cycles but nothing happens. The motor seems to gurgle while attempting to fill with water - but no water comes through. We have had this problem before and the repair person...
I bought a new one and installed it myself. hardest part of installing was taking the old unit out. I compared the cost of a second repair of a 10 year old dishwasher vs. purchasing a new one. We also checked the pump and solenoid to find problems that caused the water not to enter the unit. The new one we purchased is much better, quieter, and Energy Star.
Aug 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Ice maker noise when filling
replace the water fill valve it is at the bottom where the water line conect to the unit
Nov 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Tricity Bendix 24 in. DH102 Free-standing Dishwasher Logo
326 people viewed this question
Top Tricity Bendix Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
