Question about Roundup Garden
Round up accident sprayed on grass when i was spraying sidewalk, the lawn about 2 inches in is browning what should i do?
  • 6,784 Answers
Hi, this stuff works fast so , if you can isolate the affected plot that was sprayed, this will help. you can do this by scalping the spot that was sprayed. pull up as much of the affected grass and the roots as well. the roots will ultimately spread this over the entire yard if there is a considerable saturation due to a rain event or watering situation. do not water this affected section of the yard until you have extracted the grass that was unintentionally sprayed.
Please rate and god bless:)
Posted on May 17, 2009
My daughter sprayed round up on my lawn. How do I repair it?
Put a light layer of top soil on the dead spots and re-seed the areas. Make sure to water regularly.
Jul 09, 2012 | Roundup "" Weed & Grass Killer
Tip
Less cleaning of undercarriage of lawn mover
before you start mowing.....turn motor to see undercarriage.....spray with the brand Pam cooking spray (all over)..........(1) cleanup will be LOTS easier; AND, (2) Pam is safe for food.........so safe for your grass...!!
on Jun 07, 2015 | Garden
I have the Ortho Dial and Spray and am applying the Round-up Weed and Grass Killer. States a 6 oz feed rate per gallon and that this should cover 300 sq.ft. I pour 24 oz into the container which should...
I'm sorry to hear about the problems you had with the Ortho Dial N Spray. This hose end sprayer empties about 2.1 gallons per minute, so you will need to walk fairly quickly to cover area you're wishing to apply product to. Please give Ortho a call at 877-465-5160, and we will be happy to assist you further.
Hilary @Ortho
Sep 03, 2011 | Ortho Dial N Spray Hose End Sprayer
I will be applying Roundup to a large section of my lawn to kill a bermudagrass infestation. Will the Roundup work better on longer grass or a freshly mowed lawn?
Round up will work on any grass...I prefer to mix it a bit stronger when I know I am trying to kill grass... but yes it works... ask my daughter who wanted to help and spray the weeds for me and then decides to play around in the yard writing her name....:-)
It can take a week for a full killl though...
heatman101
Aug 12, 2010 | Roundup "" Weed & Grass Killer
I recently used ROUNDUP on a lawn The product did its job, the weeds are gone, so is some of the grass near the spray. It has not rained since the spay went on - maybe 10 - 12 days. How can I restore the...
Your grass is probably dead as well. Roundup is a non selective herbicide and will kill anything green. So take care when applying. Even green stems of young trees. Shield from spray when spraying. The best is to plant new grass. Roundup stays active in the soil for around two weeks despite what Monsanto says so add new topsoil when laying new runners or a new block of grass. Rain is no issue except within 6 hours of treatment. You can water the lawn with no problem now. Good luck and take care-Roundup is a poison that does affect our hormonal balances especially women.
Aug 04, 2010 | Roundup "" Weed & Grass Killer
When can I plant grass after using Roundup?
You can plant or replant as soon as the weeds you sprayed are dead. Roundup is deactivated upon contact with the soil, it only affects the plant material sprayed.
Jun 07, 2010 | Roundup "" Weed & Grass Killer
I have a Scott's rotary spreader that I use to spread Scott's Turfbuilder Plus 2 on the lawn. The problem is that the material collects on the rim of the wheels, and then dispenses in tracks on the lawn,...
It sounds to me like your grass is wet when you're applying, which is what the label calls for if you're trying to kill weeds. But is this wet grass maybe TOO TALL when you're pushing the spreader through it?
Next time, try mowing the lawn, then waiting 1-2 days before applying Turfbuilder Plus 2.
If anything were to work as anti-stick agent on the wheels, it would be Pam spray from your kitchen cupboard. Spray, let sit a while, then buff dry.
Apr 24, 2010 | Earthway 2050su Broadcast Spreader
I want to know how to camouflage a jeep the best
Knowing how to paint a Jeep in camo patterns means you can hide your Jeep in the woods, marshy areas or in open fields without it being easily seen. Using Mossy Oak's Shadow Grass pattern, paint your Jeep with natural-looking shadows and grass blades. The 3-D look of this pattern allows you to easily hide your Jeep from water fowl, doves, deer and big game.
Things You'll Need:
  • Sandpaper (120 and 800 grit)
  • Wax and grease remover
  • Lint-free towel
  • Camo stencil
  • Masking tape
  • Masking paper
  • Respirator mask
  • Automotive primer
  • Automotive paint (black, gray, light tan and brown)
  • Automotive clear coat
  1. Sand the surface of the Jeep with 120-grit sandpaper until the surface is dull. You can use a dual-action sander for this step to speed the process. This removes the top clear coat and prepares the surface for primer. Primer won't stick to a shiny surface.
  2. Mask off areas of the Jeep that won't be painted, such as the windows, tires and passenger area of the Jeep. Wipe the surface with wax and grease remover and a lint-free towel.
  3. Spray primer on the Jeep in three thin coats. Allow each coat to dry completely. Once the primer is dry, use 800-grit sandpaper to sand the top layer of primer until smooth. This leaves a smooth surface for the paint. Wipe again with wax and grease remover and a lint-free towel.
  4. Paint a thin base coat of gray on the Jeep. Cover all of the primered areas on the Jeep so that no primer can be seen. Allow the paint to dry.
  5. Go over the Jeep with brown paint, spraying small areas of brown paint in no particular pattern. The finished effect should look like the Jeep is equally painted gray and tan. Hold the first stencil against the Jeep and use black paint to fill it in. Move the stencil over and paint again. Start at the front of the Jeep and work towards the rear.
  6. Move on to the next stencil and use light tan paint to spray the grass pattern. The grass should start at the bottom of the Jeep and reach up towards the top. For longer grass, don't spray the tops of the grass but instead move the pattern up, spray the stems longer and then spray the tops, making the grass stems long. Repeat this around the Jeep and across the hood. Go back over the grass stems with black paint, lightly spraying a few of the stems to give them a shadow look.
  7. Finish by spraying three coats of clear coat paint onto the painted areas of the Jeep. This protects the paint from UV rays and keep the camo pattern looking good.
Tips & Warnings
  • Paint is best applied using a paint spray gun and air compressor, but canned spray paint will work.
  • Never sand or spray primer or paint without using a painter's respirator mask.
Resources: Customice Camo Stencils
I really hope help you with this (remember rated this help) Good luck.
Oct 21, 2009 | 1984 Jeep CJ7
Having a hard time to fill the bag and almost not cutting grass
Well it could be your blade on the mower, over the years i have had to profect my blade sharpening skills.
sometimes when a blade is shapened its not done correctly causeing a lack in the blade tossing the grass properly and more or less turning into mulch on the lawn.
You should have your blades on a push mower if used once a week through out the season sharpened once a season then
if you have large amounts of rocks, sticks and pinecombs then 2x a year
if you only use it here and there then ushally ever 2 years is good.
another issue could be the engine bogging down when going over heavy or wet grass. this is no fun..
what I do with my lawn mower is clean the bottom and spray it with PAM cooking spray has been far the best solution, spraying the bottom of the deck and blade.
Now saying that if you try this method then remember no wet grass so dont over water your lawn.
some people like to use POR 15 on the under side of their mowers as well but I havent tryed this yet but hear it works great.
so there is ways to prevent slow and no discharge into the grass catcher.
hope this helps but yes I would say clean the underside of your mower and have you blade sharpened by a professional. dosent cost much and so much more worth it.
Aug 14, 2008 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Garden Logo
441 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
