Hitachi cmt 2979
When watching digital 16:9 TV broadcast, the image is zoomed instead of leaving black edges on top and at the bottom. Is there a way we can adjust the TV?
  • 308 Answers
SOURCE: An oval-shaped rainbow-like colour pattern shows first,
It May be due to one of several things. You could have some bad filter capacitors that are allowing electrical "noise" to disrupt the video, or there could be a bad solder connection or crack in the circuit board allowing a ground to "float", or there could be a problem in the Degaussing circuit, although that would be my last guess. I don't recall ever having that particular problem with any sets in my shop.
Posted on Dec 16, 2006
  • 244 Answers
SOURCE: Picture too tall. How do you shorten?
Picture displaced vertically, picture too high or low
This problem was cured by entering the service mode (menu then 4,7,2,5), then pressing the green fastext button to access geometry settings, selecting VP1 (vertical position) and adjusting as necessary
Very low width and bowed verticals,no ew correction. R626 o/c
C630 (390nF, 300v) faulty, located next to scan socket. This fault can also be caused by R629 (2R7 fusable) o/c. In my set C630 was dry-jointed but not faulty. Check generally for dry joints in the E/W and PSU areas. Note that R629 is a safety component
Posted on Nov 24, 2007
  • 13 Answers
SOURCE: Sony WEGA KV-27FS100 picture size
get an hd tv try lcd dlp or plasma you will get a better picture
Posted on Jan 22, 2008
  • 317 Answers
SOURCE: Screen goes black when watching TV in HD
ck all cables.
Posted on Aug 03, 2008
SOURCE: Zoomed screen on my TV
with remote control use Zoom boton, or enter to menu and seek for this option.
Posted on Oct 23, 2008
How do I make the picture bigger so it fills the screen and not have black bands at top and bottom
Banding of the screen usually means that the aspect ratio of the broadcast is different than the screen size ratio. Most modern TVs are 16:9 ratio. Most modern TV broadcasts and movies are as well. In those cases, when in HD mode, you will see the picture fill the entire screen. Older broadcasts and many syndicated reruns are in the old 4:3 format and will be banded. Also, some movies are in larger formats than 16:9 and will reduce in size in order to get the entire picture on the screen. That being said, most TVs DO have a stretch and.or zoom feature that will expand all images to full screen size. Be advised that this can result is image distortion, especially of the 4:3 ration broadcasts. Others will have some of the picture cut off and you may see some items such as network logos, etc. partially chopped off in this mode.
Mar 13, 2015 | Televison & Video
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
SHARP AQUOS 46INCH CANT GET A FULL PICTURE ONLY IF I USE ZOOM WILL THE SCREENBE FULL
Hi Anthony,
You're describing what is called letterbox and pillerbox. Letterboxing is when there are two horizontal bars - one at the top and one at the bottom of the screen with a wide picture between. Pillerbox is when there are two vertical bars - one on the left edge and one on the right edge of the screen with a tall picture between.
The settings on your TV (and on your cable box, satellite box, DVD player, etc.) tell the TV how to display a picture that will not fill the screen completely. If the program source (an older video-taped TV show, non-widescreen version DVD, etc) was not originally "shot" or saved in widescreen format, the TV offers you a choice on how to display the image. They ask if they should stretch or zoom to fill the screen (and you have to deal with the skinny / tall images or lost portions of the picture); or maintain the aspect ratio (not stretching or zooming) by leaving a part of the screen blank (grey or black) by inserting bars left and right or top and bottom of the screen.
Start out by telling the devices that send pictures in a format that matches you TV's screen ratio. I am assuming you've got a wide screen HDTV which would mean it should be set to "16 x 9" (a.k.a. 16:9) ratio display. If you have it set for 4 x 3 (a.k.a. 4:3) you should change it. Look for a setting on your TV that asks about stretching, zooming, etc. as this will be an issue when receiving picture from an off air antenna on your house when a TV station is airing an older, non-wide screen format TV show or movie.
TV signals provided by Cable TV or Satellite provider must be HDTV type signals. If you have the standard TV service (non-HD) no picture sent by them will ever fill the screen. This is because Standard Definition TV (SDTV) is not capable of those types of signals. You will have to bump up your subscription to HDTV service to get full screen pictures.
I hope this helps!
Nov 10, 2011 | Sharp Televison & Video
Black bar on the top and bottom during watching the tv
Hello
If you are watching television and you see black lines on the left and right sides of the screen, check to see if you are watching an HD broadcast or a standard definition broadcast. You can do this by bringing up the TV guide menu on your remote. If the show is in HD, it should take up the full screen. However, if it is not HD, bars will be present on the left and right of the screen. That is because standard definition programing is in 4x3, which will not take up the entire screen.
If the picture you are watching not only has black bars on the sides, but on the tops and bottoms of the screen as well, your "Zoom" mode has somehow gotten off-kilter. Press the "Zoom" button on the remote until the image appears correct. If this does not work, power down the television, wait a few moments, and power the TV back on. The image should be correct now.
If the image on the screen looks stretched or squished, this is because your HD cable receiver is not set up properly for your widescreen television. Press the "Menu" button on the receiver
May 06, 2011 | Samsung 50 in. Plasma TV
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
How do I change it from wide screen to regular? I have a black area above and below the picture.
Hello
You can set the picture size by remote control itself.
You can vide 480i format programmes in three picture sizes. 4:3, 16:9, and ZOOM
You can change the picture size by pressing the PICTURE SIZE button on the remote control.
4:3 Picutre size
To fill the screen, the top and bottom edges are extedted more widely, although the center of the picture remains near the former ratio.
If receiving a 4:3 programme, the image size is displayed in its originally formatted proportion.
16:9 picure size
This image displays the size of standard 16:9 with black bars at the top and bottom.
If receiving a 4:3 programme, the image is displayed with black bars at the top and bottom and stretched wider.
NOTE: If a fixed bar remains on the screen for a long period of time, the image can become parmanantly engrained in the screen and cause subtle but permanent ghost images. Never leave your TV for long periods of time while it is displaying these images.
Zoom picture size [for 16:9 formats]
The entire picture is uniformly enlarged --it is stretched the same amount both wider and taller (retains its original proportion). The right and left edges of the picture may be hidden.
OK.
Dec 14, 2010 | Insignia NS- 27" TV27 TV
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
I just bought a ilo tv model dtv2794b and playing vcr's is ok but when i try to play dvd's i get big black lines on the top and bottom of the screen like i am watching a wide screen movie, there is a...
Most if not all DVD's are 16 by 9 even in 4.3 mode you are going to have those bars on this TV. Some television have a zoom feature to get rid of that but not this one.
Jan 14, 2008 | Televison & Video
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
