Question about LG 42PX5D 42 in. Plasma HDTV
Frame is off to the right
Hi i have a lg42" plasma tv(mod no 42pg3000 software version v3.03.1) and the frame is set to the right no matter what i have the aspect ratio set to to get full screen i have to zoom x1. is there a user solution to this or is it a repair in the shop.
    President:
  • 1,077 Answers
Before taking it to a repair shop, let's try two ideas.
Try Picture Reset option,
Press Menu,
select Picture,
select Picture Reset, then press OK.
If that doesn't work, try Reboot/Restore factory settings,
Press Menu,
select Option,
select Factory Reset, then press OK. (if you forgot password, use 7777 )
Posted on May 17, 2009
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
Can i connect my bose companion 2 speaker to my 42pg3000 plasma tv
yes audio out of your plasma tv use cable bose companion 2 Audio Input Cable with RCA plugs and try
May 20, 2012 | LG 42LG50 42 in. LCD HDTV
How long should it take to load a software upgrade on a Philips plasma tv?
The Firmware softwares upgraded to the main frame CPU chip it take about 20-25 mins.Best way it is to download the Firmware softwares to a memory stick.Than stick it into the tv USB port to upload to the tv.Because download directly from the net it is dangerous any interuption of the flow of the data's to the tv and cause a mishap to the tv main frame CPU chip,than the CPU chip is a paper weight scrap CPU silicon chip.Than the board is dead and will not take in the incomming broadcasting tv signal and produce a picture for ur tv.
Apr 03, 2011 | Philips 42PF9630A 42 in. Plasma Television
My LG 42pg3000 stopped displaying hdmi inputs.
I have a similar issue. HDM1 does the same thing, did you ever find a solution?
JP
Apr 05, 2009 | LG Televison & Video
LG plasma tv picture moves frame by frame horizontally
If the TV is still under warranty, I would begin there. The bad thing about a plasma TV is that they cannot be fixed. I would watch it as long as I could stand it. When you buy a new one, be sure that you a LCD HDTV or a projection. Sorry.
Jan 11, 2009 | LG 42PX3DCV 42 in. Plasma EDTV
Black Vertical strie on plasma TV
I think you have a frame fault on the tv. If you are capable check the picture frame board first. If not find a competant technician. Good luck.
Oct 02, 2008 | Philips 42PF7220A 42 in. Plasma Television
Broken screen(S)
The Plasma Display Screen for 42PC3D is listed below.
LG 42PC3D Plasma Display Panel Replacement
Apr 13, 2008 | LG 42PC3D 42 in. Plasma Television
Lg 42" plasma
This may be in part with the X - Y addressing to the screen. The fault can be a bad ribbon cable, or a failed drive board. On rare occasions it can be the screen itself.
Proper troubleshooting would be required to actualy determine the exact fault.
The cost will not be cheap for this type of fault. For some of these types of faults, the cost can be more than a few hundred dollars to start.
Jerry G.
Dec 01, 2007 | LG DU-42PX12XC 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
224 people viewed this question
Computer Repairing
Computer Repairing
