Question about Franke Home
Drain stopper is stuck
Drain stopper working won't come out of the sink stuck locking mechanism
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 111 Answers
Try turning the top of stopper with fingers. They are generally " locked in with a twist" and can be unlocked the same way. good luck!
Posted on Sep 01, 2014
4 Suggested Answers
  • 19 Answers
SOURCE: CHIPPED PAINT ON BATHROOM SINK DRAIN STOPPER
you need to remove the brass ring from the tub and buy acan of spray paint for metal you will be able to find it in a brass finish
Posted on Feb 02, 2009
  • 63 Answers
SOURCE: Bathroom sink stopper came unhooked and out, not attached anymore
You will need to get under there and unscrew the popup rod located on the back of the drain. pull out the rod, drop the stopper in there and push the rod through the hole in the bottom of the stopper. screw the nut back on.
Posted on Mar 16, 2009
  • 30 Answers
SOURCE: Our bathroom pedestal sink is very slow drain and
You shouldn't have to disassemble everything in order to get to the trap (elbow joint). Most pedestal sinks are designed so that you can get to the trap from the back (generally after getting down on your hands and knees and crawling around with a flashlight). Most sink stoppers that are worked from the faucet itself have a little bar that extends down the back of the sink behind the drain. It will clip with a little metal piece to a lever that sticks out the back of the drain before the trap. The lever goes through a hole in the drain and pokes into a hole in the bottom of your sink stopper. As you move the lever, you will notice that your stopper goes up and down.
Unclip the rod from the lever and you should be able to unscrew the lever from the back of the drain (don't loose the little gasket that sits inside the screw-cap as it keeps water from leaking out here). At this point, you can pull out the stopper and see what is going on. If cleaning off the stuff attached to your stopper doesn't solve the problem, you can then remove the trap to see if anything is clogging that. Hopefully, by this point, your sink clog has been identified and you just need to reassemble, making sure when you put your stopper lever back in that you actually get it into the appropriate hole in the stopper itself.
If this doesn't solve your problem, it's more serious and you probably want to call a plumber as the issue is either a clog farther along or a problem with the venting of the sink drain.
Posted on Sep 18, 2009
My son put tp down the drain. How do I remove the sink stopper? Doesn't seem to unscrew?
it unscrews but from the underneath up
you will have to remove the "S" trap only as what ever it is will be stuck in that bend
Jan 04, 2016 | Plumbing
Tip
Backed Up Kitchen Double Sink Fix with Garbage Disposal- Quick and Simple Fix
Here's how to fix a backed-up double sink (running water down one side/sink causing dirty water to well up out of the drain on the other side, with slow or no emptying). Note that this quick-and-easy tip only works if you have a functioning garbage disposal.
What you will need: a stopper, and possibly a clean toilet plunger (the cup-shaped kind that stands on its own, not the kind that is bulb-shaped)
Stopper up the side in which the water is rising up out of the drain. Make sure you hold down the stopper as well; if you don't, the stopper will shoot up on a geyser of dirty water when you perform the next step. Once you have the stopper in place and are holding it down, run water on the other side/sink and turn on the garbage disposal. Once you have done that for a reasonable amount of time, shut off the garbage disposal and water, and unstopper* the other side. Run water on both sides to make sure everything is draining properly. Doing this should save you the hassle of taking the pipes apart or plunging one side repeatedly to clear the clog.
*Note: If the stopper is stuck, place the plunger so it completely covers the opening the stopper is stuck in and give it two good plunges. The plunger should create a vacuum that will suck out the stopper, and is more effective than you trying to pry or pull on it. Do this ONLY after you have shut off the garbage disposal and water.
What is happening is that there is a clog in your pipes. When water goes down one side, it hits the clog somewhere in the pipes, has nowhere to go, and gets pushed back up the pipe leading to the other side of the double sink. By stopping up the side without the garbage disposal, you are creating a barrier preventing the water from coming back up. At the same time, the garbage disposal running on the other side is forcing the water down. Since the water now cannot escape up the stoppered side, it has nowhere to go but down, forcing the clog out with it.
on Jun 28, 2014 | Home
Tip
Simple Removal of Stuck Sink Stopper
I found an easy solution to removing a stuck stopper recently when I was fixing my kitchen sink and the stopper became vacuum-stuck. Instead of trying to pull on it (which will not work since the pressure is too great), or trying to release the vacuum by prying up an edge with a knife or other instrument (which would damage the stopper or sink), I used a (clean) toilet plunger to plunge the stopper out. Simply place the plunger squarely over the opening where the stopper is stuck and give it two good plunges. I got the stopper stuck several times while fixing the sink and this trick worked every time for getting the stopper unstuck. Make sure you are using a plunger that's cup-shaped (stands upright on its own), and not the kind that has a bulb at the end.
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
I have a glass bowl sink in my bathroom. The pop-up drain is stuck in the down position and will not release. How do I fix it??
You'll need to access back side of sink bowl and locate drain mechanism, most likely either the plunger rod has loosened up from clevis rod or clevis rod is positioned to far in towards drain line causing it to bind. Check diagram for assistance in locating parts.
Is the plunger rod tight or loose? You can also loosen clevis screw and see if the plunger rod will slide freely. If it does try moving the horizontal pivot rod up and down, while doing this you should she your drain plunger moving up and down. If it does not then most likely will need to replace plunger mechanism by removing the retaining nut on the back side of the drain line. This will allow you to disassemble the actual drain plunger but I would definitely start with the mechanism of the stopper and clevis where it attaches to horizontal rod.
Sounds like a simple binding. Always be sure there isn't anything stored under your sink which could be causing the problem. Sometimes the most obvious is the last thing we look at.
Good luck.
Aug 16, 2013 | Pegasus Technologies Pegasus Clear Round...
Pulled the drain stopper rod out and cant put it back in. how do i do it?
if you remove the actual drain mechanism you will see where the drain stopper rod goes into.It`s a hole that works on a lever. You need both hands to insert rod into and then use the other hand to find the right height position to anchor the drain stopper. You insert it from behind and then tighten the drain stopper on the drain pipe. Take your time this sounds complicated but it is quite easy. When you have it lined up you can check the operation of the rod by going up and down.And see if it holds water and then see if it drains the water..
Feb 19, 2011 | American Standard 0456.017.222 Heritage...
My strainer/stopper is stuck in kitchen sink drain. How to remove it?
If it's not visible from above then you must remove the trap j-bend. Go under the sink and put a big bowl or tray under the trap because when you remove the j-bend water will come out. You'll need a 12" grooved pliers, like channel locks, to get the nuts off. There are two of them. If the trap is old brass or chrome you may end up cracking the j-bend. If it's white or black plastic you can probably remove the nuts by hand. Look in the j and pull out your stopper. If it's visible from above a long pair of needle nose pliers would work best to remove the stopper.
Jan 31, 2011 | Blanco Sink Waste Strainer / Stopper...
Pop up sink basin wont stay down to allow water to stay in basin
I'm assuming this is a mechanical pop up drain. If so then one of three things are happening. Either the pop up mechanism needs to be adjusted, there is build up inside the drain where the stopper is or the mechanical parts are worn and need to be replaced.
Remove the items from underneath your vanity so that you have room to work. Under the vanity the pop up will have an adjustment rod. It is possible that the adjustment has slipped resulting in the drain not closing off properly. Try adjusting the connecting rod and see if that helps. If not move on to the next step.
You will need a small pail to catch any water when you disassemble the pop up. Inside the sink put something under the stopper to hold it in an open position because when you disassemble the pop up it will drop to the closed position and may be difficult to get out of the drain. Under the sink there will be rod coming out of the drain held on with a threaded nut. Unscrew the nut and the rod will come out of the drain and deattach from the pop up inside the drain. From the top of the sink remove the stopper. Clear any of the build up which is usually a distasteful combination of hair and soap scum. A pair of latex gloves come in handy at this point. Check the pop up for wear at the point where the rod attaches. It is possible that this could be worn to the point of not working correctly when the mechanics of the pop up are moved to the closed position. Your local hardware store will have any replacement parts required.
Be sure to reassemble every component before using the sink and test for leaks. Good luck with your project.
Jul 24, 2010 | Home
Our bathroom pedestal sink is very slow drain and clogging -2 questiions: do you have to disassemble and take off sink mounts and remove from wall to get to elbow joint? I do not know how to disengage...
Aug 30, 2009 | Home
Pop up vessel sink drain
Look underneath the sink and you will find the lever that moves the drain up and down. It is probably stuck.
Jan 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
Home Logo
386 people viewed this question
Top Franke Home Experts
Gil Shultz
D Bowman
D Bowman
Level 1 Expert
Are you a Franke Home Expert? Answer questions, earn points and help others
