Pioneer "pd-m6"won't read disc in single mode or change discs with cart.
5 Suggested Answers
  • 85 Answers
SOURCE: Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Posted on Jan 08, 2009
gokomets
  • 120 Answers
SOURCE: my Pioneer PD-TM1 18 Disc player reads through all
Seen alot of these "drop" the laser lens inside the unit! Have had some luck glueing the lens back on using radio/tv cement. Don't try super glue or it will ruin the lens! No luck replace the laser!
Posted on Apr 13, 2010
gopakumarg43
  • 75169 Answers
SOURCE: i have a pioneer model pd-m430 6-disc multi-playcd that won't play. it lights up when you turn it on but no sound. it some times channel through the discs but does not play
It sounds that the opticla pickup unit has the fault. Clean it and check. If this do not help you, replace it.
For more details, just type in the site name "Electro-help" to your search engines' search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts. You can get all details.
You can locate it either at the bottom part of first search page, or at the top of second page. Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price etc:-
Posted on Jun 04, 2012
  • 444 Answers
SOURCE: pioneer PD-M306 cd changer will not eject
That is why they don,t manufactur them any more, There has been nothing but (Problems) With them doing that. It is out of (Alighnment) Just look for a good used one, You can buy a used one for $10to $ 50, To get it (Repaired) Your looking at $50 to $120,
Posted on Oct 28, 2012
Pioneer PD-M306 cd changer will not eject
Oct 22, 2012 | Pioneer Audio Players & Recorders
Pioneer PD-M40 changes through all 6 cds but does not stop to read any of them
The laser pickup assembly is at the end of life, remove top to expose the laser lens, use a Q-Tip and rubbing alcohol and gently clean, allow several minutes to dry, if no change! far cheaper to replace the cd changer.
Jul 02, 2012 | Pioneer PD-M603 6-Disc CD Changer
My Pioneer PDR 555-RW keeps reading Mon1 or Moni when I try to record my CD from my mixing board. I need to send this wedding music, and it is trapped in my board. HELP!
That's just a MONITOR indication. It means you can SEE the audio from the selected input on the record level meters for adjustment or other reasons. It won't prevent you from recording. Set your levels then hit RECORD, let it set itself up and calibrate to the disc, start your source and hit Play or Pause to start recording to the disc.
May 14, 2011 | Pioneer PD-R555RW CD Recorder
I need Pioneer PD-F1007 301-Disc CD Changer manual
http://www.pioneer.eu/eur/support/manuals/PD-F1007/index.html
Oct 23, 2010 | Pioneer PD-F1007 301-Disc CD Changer
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
also:
Many Magnavox, Denon, JVC,
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
Jan 07, 2009 | Pioneer PD-F805 CD Player
Won't read discs
Discs Must Be Loaded Label Side Down.
Sep 07, 2008 | Pioneer PD-M603 6-Disc CD Changer
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
63 people viewed this question
 Grubhead
Grubhead
