Question about Coleman Roadtrip Grill LXE 9949-750
I have a coleman road trip grill. I have a 20lb. tank that I hook up to with a 3ft. line . However, only one burner lights. When I attempt to light the second burner they both choke out. I have a new regulator, ruling that out as the culprit. Any ideas?
4 Suggested Answers
SOURCE: Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Posted on Jul 17, 2008
  • 494 Answers
SOURCE: Where can I get the fuel line that connects the
Take the entire grill to your local propane company, so they can look at it and replace it on site for you. Call around first, as some places no longer have a repairman on site at any given time.
Douglas
Posted on Sep 09, 2010
  • 4736 Answers
SOURCE: coleman road trip is hooked
Lloyd, the regulator isn't working. But the problem generally, easily solved, if you follow the directions below.
To solve this problem, first be sure you have adequate gas in the tank. If that checks out OK, do the following:
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! And thanks for choosing FixYa.
Posted on Jul 28, 2011
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
What is the chain for in a coleman road trip sport grill
It is called a Match Extension. It lets you use an ordinary book match to light the burner by placing the lit match in the wire loop and holding it near ththe burner
Jun 10, 2012 | Coleman RoadTrip Sport Grill 9944-851
Coleman road trip is hooked to a 20 lb tank but when turned on, small amount of gas comes, then quits. appears to me as if regulator is not working. cannot use grill at all. lloyd
Jul 28, 2011 | Coleman Roadtrip Grill LXE 9949-750
My7 Baby q doesnt get hot enought to sear steaks
Their are several things that can cause this problem:
1. The burner(s) need to be removed and thoroughly cleaned.
2, Low amount of gas in the tank.
3. The grill's gas regulator is partially seized.
The first two are easy for you to solve, The third one is to if you do the following:
Turn the gas tank valve OFF. If you're using a 20lb LP Gas grill tank, disconnect the hose from the tank and wait 5 minutes, If you're using a small 1 lb cylinder, turn it OFF and remove it from the grill. after 5 minutes, reconnect the hose to the tank or reinsert the small cylinder and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open light the burner(s) and turn it to the highest setting. Did the burner light and does the flame height look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If the above didn't solve the problem, you will need to replace the grill's hose/regulator assembly (if you're using a 20Lb LP Grill Tank). Which you can find at any home center or hardware store that sells gas grills and accessories. If you're using the smaller insert-able tank, you will need to replace the tank's hookup and regulator mechanism.
Jun 03, 2011 | Weber Baby Q Grill
Does not start. manual start doesnt work either.
First, is your grill on a cart or built in to an island? Secondly, are you using a 20lb propane tank to fire the grill or is it hard piped to the grill from your house? And finally, has it been converted from Propane to Natural Gas?
If you're using a 20lb LP Grill Tank are you sure there's still gas in the tank? Did you just installed a new, full tank recently and the problem started after that?
If the latter is the case, turn off the grill tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY, until it's fully open. Light each burner one at a time and turn then to high flame. Do the flames look normal? Are they the proper height? Is so, you just solved your problem. Remember to turn the tank valve on very, very slowly after turning it off each time.
If you grill is hard piped from your house, be sure that the gas line shutoff valve is turned ON.
Hope this helps solve your problem.
Feb 15, 2011 | ProFire PF27G Grill
Can't get q to run on 20lb tank
When you hook up a 20 lb tank to your Weber Q, only open the tank valve 1/4 turn, light the grill, then open the valve the rest of the way. Also, make sure the air inlet on your burner is not obstructed. Its easy to remove the burner and just wash it in hot soapy water and that sometimes can cure the problem as well.
Nov 19, 2010 | Weber Baby Q Grill
Colman stove won't light
Here's the way these oldies work:
1. Make sure you've got fresh Coleman fuel or equivalent in the tank.
2. Make sure the cap is tight on the tank.
3. Unscrew the pump knob counterclockwise about 1/2 to 3/4 of a turn.
4. With your thumb covering the hole on the pump, pump the tank about 15-20 times, then screw the pump handle tight clockwise.
Then you can turn the little lever knob to the light position (I believe it is in the up position) and then crack the fuel knob open a bit and attempt a light of the burner with a lit match. As it warms up you can turn the lever to the opposite position to obtain a good flame...
Best to try this before you leave for your trip...
May 29, 2010 | Coleman 2 Burner Dual Fuel 424-700G Grill
Propane tank
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Coleman Roadtrip Grill LXE 9949-750 Logo
105 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
