Question about Dishwashers
Replace control panel dishlex 103 sx - Dishwashers
3 Suggested Answers
  • 12 Answers
SOURCE: Hello. Can i put
Yes but it must be a material that is made to withstand the heat dont cover any vents or spaces around the dishlex
Posted on Nov 09, 2008
SOURCE: Replace Control panel cover on dishlex dishwasher 500E
If your 500E is the same as my 500E then the controls are electronic touch buttons. The are part of a self adhesive strip and stuck to the front of the door. No screws involved. Only the LED lights are mounted on a circuit board with screws on the back of the plastic front panel. ?????
Posted on Jun 07, 2009
Ksm 103 on one speed
Remove the back cap over the speed control and look at the speed control plate while operating the speed lever. Make sure the lever is moving the plate in and out. If yes then I would replace the small PCB above the control plate, that is the electronic part of the speed control and not worth very much at all.
Jun 15, 2016 | KitchenAid Food Mixers
Where can i buy sx px 103 piano main board used.
Check Kijiji or eBay or google info with key words "for sale"
Jan 21, 2016 | Music
Why door will not latch close on 103 dishlex dishwasher ?
Check whether the dishes are touching the door before closing the door..Or the spring mechanism of the latch is damaged
Jul 06, 2014 | Microwave Ovens
Where located fuel sensor Suzuki Ario 2003
Component location diagrams for most 2003 Suzuki Aerio cars and light trucks sold in the U.S. from 1990+.
clsk2003aeri003.gifIgnition System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
Components on diagram:
  • TP Sensor
  • Ignition Coil
  • ECM
  • MAF Sensor
  • CMP Sensor
  • clsk2003aeri007.gifElectronic Shift Control System Components Location Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Data Link Connector
  • Transmission Range Sensor
  • Throttle Position Sensor
  • Pressure Control Solenoid Valve
  • Battery
  • clsk2003aeri010.gifInstrument Panel For Connector Layout Diagram Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Clutch Switch
  • Thermistor
  • Brake Light Switch
  • Blower Motor Relay
  • Heater Fan Motor
  • clsk2003aeri011.gifInstrument Panel Harness Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Wiper Switch
  • Washer Switch
  • Turn Signal Relay
  • Radio
  • clsk2003aeri015.gifHeadlight System Location Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Headlight Relay
  • Headlight
  • Clearance Light
  • Headlight Diode
  • Clearance Light Relay
  • clsk2003aeri022.gifFuel System Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Fuel Pump Relay
  • Fuel Tank Pressure Sensor
  • EVAP Canister
  • Fuel Tank Pressure Control Valve
  • Fuel Filler Cap
  • clsk2003aeri027.gifFloor For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Wheel Speed Sensor
  • ABS Control Module
  • G Sensor
  • Air Bag Control Module
  • EVAP Canister Vent Valve
  • clsk2003aeri030.gifInstrument Panel For Ground Point Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • Instrument Panel Ground Points
  • clsk2003aeri036.gifEngine Compartment For Single Unit Parts Diagram for 2003 Suzuki Aerio 2.0 L4 GAS
  • Horn Relay
  • Radiator Fan Control Relay
  • Cruise Control Module
  • Condenser Fan Relay
  • clsk2003aeri037.gifEngine Compartment Components Diagram for 2003 Suzuki Aerio SX 2.0 L4 GAS
  • MAP Sensor
  • Knock Sensor
  • Noise Suppressor
  • Heated Oxygen Sensor
  • Sep 18, 2011 | 2003 Suzuki Aerio
    How do you acces the power switch for replavement
    turn of power undo control panel screws remove panel you should see the switch replace and re assemble hope this helps
    Nov 13, 2009 | Coffee Makers & Espresso Machines
    Dishlex 302 water not heating
    My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
    Jun 26, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
    The dishlex 302SB is not producing hot water for the washing
    I have a Dishlex 302 which had this fault. Initially I thought it was the inline heater element and replaced it. It seemed to work but later no hot water again. Someone here put me on to the problem. There is a dry joint in the control board in the top of the door. This controls the relay which powers up the heater. Unplug it from the mains (very important) and undo the screws around the top of the door (don't take the door right off!) you will be able to wiggle off the front panel containing the electronics. The control board is ealiy disconnected an removed from the machine in its protective plastic cover. Have a look around the PCB and you will see the dry joint. Resolder with rosin core (electronic) solder, reassemble and you should have hot water.
    May 23, 2009 | Electrolux 504199 Dishwasher
    May 09, 2009 | Dishwashers
    Hello. Can i put an front panel on the door of my dishlex DX 103 to integrate it with the rest of my kitchen?
    Nov 09, 2008 | Dishwashers
    Dishwashers Logo
    20 people viewed this question
    Top Dishwashers Experts
    Owen Barnes
