Question about Ecoquest Fresh Air Air Purifier
Fan turns off and comes back on several times a day
The problem is the above fan turns off and comes back on several times a day
Why is the blower fan in my 1000 turn on and off constantly? Its brand new!!
I had 2000w blower fan and it was turning on/off just like your fan due to it's overheat protection.
If your fan turns off in short time(like 10 minute); i suggest you to use your warranty and return your fan back to seller.
Nov 21, 2014 | Air Purifiers
Bleeding the radiator
take the top off the header tank ( part you fill the water in) top to the top run engine until it boils or fan kicks in to cool down the engine. while it is heating up squeeze the pipes around the engine to help release the air better DONT put your hands near any moving parts. keep the water full to the top while doing this. when at temp turn off engine and leave to cool down dont add any water or do anything till it has cooled down. when cooled down top up to the mark and should be good then if not then the thermostat may be faulty. or you have a blockage some were in the system that is causing the over boiling problem also check that the fan is working and the temp switch for the fan is working all these can make the engine over heat, also when bleeding the system have the heater on number one and heat on full.
Apr 02, 2014 | Spectre 2001 Chrysler Concorde - 2.7L V6 -...
Holmes blizzard table fan
take it to your nearest gas station and get the air hose and spray it with the air then take some w-d 40 and with the long red tube attachment that comes with it spray it in the middle moving parts of the fan.the air from the air hose might turn the blades so stick a pencil or something in there first to keep blades from rotating then spray the dust off the blades with the airhose
Jun 16, 2013 | Holmes HAOF90UC Blizzard 8" Three-Speed...
Fan turning on and off
Check your filters make sure that they are clean, and/or it could be a malfunction in the sensor
May 05, 2012 | Ecoquest Fresh Air Air Purifier
GETTING FAN OFF
Plastic tends to conform to the metal shaft over time, however they will usually come off intact. If there are ears on the retaining clamp, press those together to expand the clamp and remove it from the fan hub, then carefully apply pressure tot he back side of the hub to extract it off shaft.
If you cannot get easy access to it, sometimes gentle rocking of the fan blade from the hub will free it once the clamp is removed.
Feb 01, 2012 | Ecoquest Living Air Classic Air Purifier
I've had my AT Breeze since 2004 The fan motor is beginning to make noise. is there a fix or do I need a new motor?
Remove the front grid. Pull firmly but gently on the fan blades to remove them from the shaft. Turn the machine on its back, open front facing up. Use a light household oil (sewing machine, hair clipper, or 3-in-1) and squirt a small amount down the shaft, turning the shaft as you do so. You may need to do this several times, until you can feel the shaft move freely. If this doesn't help, your only option is to use the machine as a $100 trade-in credit for an upgrade. The new company, Vollara, is no longer manufacturing nor repairing the Breeze. (1-800-989-2299) Some dealers may still have Breezes in stock, and some may also have parts, but you'd have to locate them yourself.
Jan 24, 2011 | Ecoquest Breeze AT Living Air Purifier
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
Honeywell F 50 F air filter
take out the cells, they weigh about 8 pounds apiece. Make sure you remove both. Put the door back on and turn the fan in the furnace on. IF the light on the power supply comes on, then the power head is most likely good.
Then insert one cell at a time, individually. Push the single cell in all the way to the back, put the door back on, if the light is on, that cell is fine. If the cell does not come on, there is most likely a bent fin on the cell. simply bend the fin so it does not touch the other fins and you should be fine. Repeat this step on the other cell.
Make sure the door to the filter is closed, the power switch is on and the furnace fan is on.
Good luck.
Nov 18, 2008 | Honeywell (F50F1032) Air Purifier
Alpine XL-15 fan has stopped working
Hello night light,
How you proceed is going to depend on how comfortable you are taking it apart.
Given it's age and purchase condition, warranty isn't an issue. You will either be able to dis-assemble the purifier and try taking the motor apart and reassembling, or you can find a replacement motor (I've seen some on the web, they start at ~$50).
Another possibility is that the fan pot (the rotary switch that the knob turns to adjust the fan speed) may be out. If you have a multi-meter, see if you can get a signal through (when it's all the way open). If not, try replacing that first. Parts are available onthe web, I can't advertise per FixYa's terms of use.
Hope this helps.
Sep 28, 2008 | Alpine Air XL-15 Air Purifier
Ecoquest Fresh Air Air Purifier Logo
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
