Question about Eemax EX280T2T Series 3 Whole House Electric Tankless Water Heater
No hot water
I have a eemax ex280t2tdr. the temp gauge reads 82 degrees. The water does not get hot. any suggestions.
thanks
  • rontay9999 May 17, 2009
    The unit has been operating correctly for 1 and 1/2 yrs. Installed new when home was built. Stopped operating correctly yesterday
    President:
  • 3,433 Answers
82 degrees is quite low for a water heater. reset to 100 degrees and it should heat up.If hot is a concern . 100 is less than two degrees above body tem, It can easily be cooled dow using cold water mix.
Posted on May 18, 2009
  • 547 Answers
In and out hooked up right?
Posted on May 17, 2009
I have a Eemax so 35 instant water heater and it makes a buzzing noise when you turn the hot water on
Heavy current required for instant hot water may be switched via a relay or contacter which may be faling. One way to diagnose may be with cover off and careful listening and visual inspection, but a risky process for inexperienced DIY'er's ??. Pro time?
Apr 11, 2017 | Eemax Water Heaters
My water is too hot eemax sp 90
Water heaters have thermostats so that you cand adjust the temperature of the water. Temperatures above 120 degrees can pose a scald hazard.
Jul 15, 2014 | Water Heaters
Eemax280t2t no hot water
see if the circuit breaker switch has tripped either partially or fully and reset it. Check for bad or loose wiring on the heater and breakers. The next thing is more likely the heating element is no good and needs repaired or the heater needs replaced.
Jan 30, 2014 | Eemax Water Heaters
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
Wher does white wire go on ex 190 eemax water heater
It runs off 220v, meaning there are two "hots" and a ground. The 190tc uses TWO sets of 220v at 40amps each. Instead of only having one dbl throw breaker, you need 2. Having said that... the white wire "should" be the same as the black wire and can be connected which ever way you like
Jan 17, 2011 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
Fluctuating water temp. It is hot when I start the shower,
Iam guessing your using it faster than it makes hot water. May need a larger unit or a second one,in the system
Apr 10, 2010 | Eemax ELECTRIC DE-IONIZED TANKLESS WATER...
Takes longer for water to get hot at sink and shower and bath tub does not get hot.
The boiler temperature setting is kept at a position lower than you need. Go to the boiler. There will be a small box with a knob. The knob generally has 3 settings marked. Cold or Vacation, warm and Hot. If you inspect it closely you will also see a rd dot marked on the body. If my guess is right, the red mark and warm align in your case. Turn the knob a little towards the hot. However, test your setting after a little time and adjust to the best setting that suits you.. If your temperature controller is in good working condition, water could get really hot. So, tely everyone in the house that you have changed the setting to hot. Other wise you know, severe scalding could occur. If this did not work you may need to change the thermostat. The element seems to be work because the water is heating up at least a few degrees.
Jan 22, 2010 | Eemax EX144TC 15.0kW 240V
Our 606 reliance electric hot water heater has the letters a b c for the temp control not 120-160 degrees. On what letter a-b or c should the temp be set on to get 120 degrees
We will just assume that "a" is the lowest temperature
to correspond to 120 degrees, while "c" for 160 degrees.
So try setting it at "a" and feel the hot water that flow.
Or it could be the other way. Just feel the hot water that
flow. It will be done in a few minutes. I hope this will help
you.
Nov 26, 2009 | RELIANCE ELECTRIC WATER HEATER
My eemax ex120tc 11.5kw 240v the water does not get hot enough.
you can check elements with a meter to see if they are any good. how old is heater?
Feb 04, 2009 | Eemax EX120TC 11.5kW 240V
Eemax EX280T2T Series 3 Whole House Electric Tankless Water Heater Logo
270 people viewed this question
Top Eemax Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you an Eemax Water Heater Expert? Answer questions, earn points and help others
