Question about Treadmill Doctor Pacemaster Platinum Pro VR Treadmill Walking Belt from Pacemaster
Error code 307 - Treadmill Doctor Pacemaster Platinum Pro VR Treadmill Walking Belt from Pacemaster
Need to find fuse control for ford five hundred 2004 cruise control
Do you mean 2005 ? Didn't have five hundred in 2004 !
Speed Control The speed control system consists of the following components:
  • speed control switches
  • speed control deactivator switch
  • speed control indicator
  • powertrain control module (PCM)
  • electronically controlled throttle body
  • clockspring
The speed control system is controlled by the powertrain control module (PCM). The speed control system is designed to maintain a selected vehicle speed between 48 and 200 km/h (30 and 124 mph). The speed control system is controlled by the steering wheel mounted switches (ON, OFF, SET+, SET-, CANCEL, and RESUME), and the brake pedal. The steering wheel mounted switches are hardwired to the PCM.
The speed control functions include:
  • turn the speed control system on
  • set and maintain the desired vehicle speed
  • accelerate the vehicle speed
  • decelerate the vehicle speed
  • resume the prior vehicle speed
  • turn off the vehicle speed control system
  • cancel the speed control
  • Smart junction box (SJB) fuse 18 (10A
  • Powertrain Control Module (PCM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action P0579 Cruise Control Multifunction Input A Circuit Range/Performance PCM Go To Pinpoint Test C . P0581 Cruise Control Multifunction Circuit High PCM Go To Pinpoint Test C . P0720 Output Shaft Speed Circuit Fault PCM REFER to Section 307-01A or Section 307-01B . P0721 Output Shaft Speed Circuit Fault PCM REFER to Section 307-01A or Section 307-01B . P1500 Vehicle Speed Error PCM REFER to Section 307-01A or Section 307-01B . P1501 Vehicle Speed Error PCM REFER to Section 307-01A or Section 307-01B . P1572 Brake On/Off Failure PCM Go To Pinpoint Test B . P1703 Brake On/Off Failure PCM Go To Pinpoint Test B . Highly doubt a fuse problem . Take it to a qualified repair shop.
Jul 18, 2017 | Ford Cars & Trucks
How to fix cruise control on a 2006 ford freestar, does not work at all, wont turn on
Note the diagram, at least check the fuse. Check trouble codes, related to cruise control. to check codes yourself, at least, you need an obd2 code reader that will read po codes as well as manufacturer specific codes. It is worth the investment, in my opinion. Make sure the brake lites work.
Mar 05, 2017 | Ford Cars & Trucks
ERROR CODE P0571
EOBD code means Brake or cruise switch,wiring or ecu error
Apr 04, 2014 | 2005 Peugeot 307 1.4
ERROR CODE P0341, P0609, P0571
EOBD Codes:
  • P0341 - Cam Position Sensor signal error- check wiring.connector,bolted securely. Or sensor itself damaged.
  • P0571 - brake switch wiring or ECM problem
  • P0609 - VSS-vehicle speed sensor output -ECM problem if wiring is OK.
U0500 error code
Invalid data received from various possible modules. You need someone with a GOOD scan tool to help diagnose.
Mar 07, 2014 | Cars & Trucks
Code error 307 ricoh CL4000DN
sc 307 is a charge bias error having to do with the yellow photoconductor unit (PCU). Replacing the yellow PCU should resolve your problem. If the problem persists even with a new PCU, you will likely need to have either the high voltage supply board or the drum positioning plate replaced.
Thanks for using FixYa!
Nov 24, 2010 | Ricoh CL4000DN Laser Printer
What is error code 161
http://www.howtomendit.com/answers.php?id=12813
It is all explained above, and more.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=lwik-3sr4pw
Above are the error codes and explanations.
161
(Dead battery.) 1. Go to Checking the Backup Battery
2. Backup battery.
3. System board.
http://www-307.ibm.com/pc/support/site.wss/LWIK-3RUQGS.html
Above is your support link, so you can download a manual etc.
Sep 22, 2010 | IBM ThinkPad 600E 2645 Notebook
Maual to safehouse burglar alarm Model 49-307
Not sure about model 49-307, but it's probably the same as modle 49-537...
1) hit *
2) enter old code (which after power-on reset is the factory default of 1234)
3) hit * again
4) enter your new 4 digit code
5) hit * one last time
Your new 4 digit code should now work to arm and disarm it.
If you enter any wrong digits hit the # key to clear the error, and re-enter the code.
hth,
Paul W.
Mar 23, 2009 | Home Security
Riso HC5500 System Error - Restart!
I need help with the error code. s04-307 in my riso hc 5000
Oct 22, 2008 | Office Equipment & Supplies
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
Treadmill Doctor Pacemaster Platinum Pro VR Treadmill Walking Belt from Pacemaster Logo
21 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
fordexpert
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
