Question about Grandstream GXV3140 IP Multimedia Phone
Firmware upgrade fails gxv3140 - Grandstream GXV3140 IP Multimedia Phone
Denon AVR-1912 firmware upgrade failed
I'm having the same problem, Denon has taken down the firmware upgrade for yours ( and mine) AVR-1912. My receiver is also stuck in the update fail loop. Supposedly they will have it back up, but I don't know the timeframe.
Lots of others are having the problem with the firmware upgrade. Go to
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/16380
and that should help you out, though I can't say how much. I've gone as far as resetting the microprocessor, but it keeps trying to update, and then fails...
Dec 12, 2012 | Denon AVR-1912 3D Ready A/V Receiver - 90...
We have a 3CRWDR101A-75 3com wifi router and its not upgrading the firmware, I downloaded the firmware from the site and then when I try to upgrade all I get is file verification failed... any thoughts...
The downloaded file is "corrupt", and thus it fails the "verification" process.
Download the firmware again, and compare the two files.
Or, use a different computer to download the firmware, and to do the firmware-update.
Apr 20, 2011 | 3Com OfficeConnect Remote 612 ADSL Router
INFLATE FAILURE DOWNLOAD FILE NOW SEND RFU UPGRADE
Were you upgrading the firmware when this happened?
Try it again. If it fails again try a NVRAM reset. Download the firmware and try installing it again. If it still fails, you need to replace the formatter.
Oct 25, 2010 | HP LaserJet CP3505n Printer
Firmware Update problem.(Failed) hi i have Creative Zen 4GB Mp3 player. When i plug it via USB on my PC i can't upgrade frimware.İt always run in recovery mode.i start firmware upgrade and...
When i plug it via USB on my PC i can't upgrade frimware.İt always run in recovery mode.i start firmware upgrade and installer says "firmware upgrade failed.".Media explorer says Storage Media is 50 mb.Please help i don't know anything to repair it...
Feb 21, 2010 | Creative Labs Zen Digital Media Player
RCA LCD l46wd22 failed firmware upgrade
You probably want to contact RCA technical support. As far as I know though there is no force that you can do and most likely you will have to replace the main board. Anyway contact RCA technical support. Was there a particular reason you were updating the software?
Nov 11, 2009 | RCA L46WD22 Television
Power Light Blinks, can't communicate with Linksys Network Adapte
Seems to be a common issue among these routers. If you tried to upgrade the firmware via wireless connection then it will generally fail. It is recommended to upgrade through the wired connection. In most cases if the upgrade failed and will not reset, most likely the firmware on the router has been damaged. Your best bet is to purchase a new router.
Mar 14, 2009 | Linksys Wireless-G WRT54G Router
SanDisk e130 - died after firmware upgrade failed
Try re-formatting the player (FAT) , run the upgrade, and format your 2gb card to FAT as well. Should work.
Mar 30, 2008 | SanDisk Sansa e130 MP3 Player
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
My 3com officeconnect doesn't work after upgrding the firmware
Are you able to login to the router? If you can reset the router to factory defaults..If you can't login to the router...Is there an external reset button on the router you could try to reset. with a paperclip? Otherwise, I had this happen on a linksys router/switch. New router time. You should just return it where you purchased the product. There was already something seemingly going wrong if it was rebooting. 3 weeks? just return it. don't even mention the firmware update. Here is the site info for 3com: http://knowledgebase.3com.com/ OfficeConnect - Firmware upgrade fails with incorrect user interface image Problem: Incorrect user interface image Problem: Firmware upgrade fails Problem: Error when upgrading firmware Problem: Incorrect firmware Problem: Wrong firmware Fact: Firmware Fact: Download Fact: Update Fact: Upgrade Cause: The downloaded .exe has not been extracted Fix: The downloaded .exe needs to be extracted by double clicking on it. When performing the firmware update use the extracted files that were obtained from the "exe" file. e.g You will obtain a "bin" or "dlf" type of file which is the firmware required for your upgrade. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | 3Com OfficeConnect Remote 612 ADSL Router
Grandstream GXV3140 IP Multimedia Phone Logo
65 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
