Question about Kenwood VR-6050 Receiver
Taperecorder no "foreward" or "backward" run ( and a "start" problem
Hey experts - call from Denmark! It´s about my Kenwood casette deck kx - w6050: when I connect it to the power supply nothing happens - then the red dot starts to blink - then when I puch the power button the display starts to blink ( both in a frekvently way) . Then after a while I can set the tape to run ("play")- but when I push the "foreward" or "backwards" button, it will only run a few seconds, then it stops. Can you solve this problem? Greetings from Freddy
  • ridderhaugen May 23, 2009
    ok - but how does the drive belts influence on the display and the red led-light?
  • ridderhaugen May 24, 2009
    Ok - I´ll go to the repair shop!
    Thank you for the advice.
  • 104 Answers
It will be one of the drive belts , its better to get a repair shop to replace both belts , i have tried replacing belts myself and they are fiddly and time consuming , if you keep playing it the way it is you will damage the motors that turn the belts
Posted on May 23, 2009
  • smirf617 May 24, 2009
    not really sure why it influences the red lights [could be due to the tape head when it connects to the tape itself ] but i still believe it is the drive belts
How to replace kenwood kx 720 belt
Take the mechanism out of the deck and take apart to get access to the belt and change it.
Jul 11, 2014 | Kenwood Audio Players & Recorders
Kenwood KX-79 CW dual cassette hook up?
Just connect the deck via tape 1 the out of the deck going to the in of the amp. While the out of the amp goes to the in of the deck.
The tape deck itself will automatically choose the player that plays the cassette. One will play the other will be on pause (if you press both play buttons) till the tape stops then the other will play. For recording from tape to tape one deck will be the copy and the other the copier. There should be a dubbing button which you press to record tape to tape. Some models have a high speed dub also. For recording from the amp unless both decks have record buttons you will only be able to record with one deck. Make certain the dub button is not set.
Dec 25, 2013 | Kenwood Audio Players & Recorders
KENWOOD KX56W/CW
I have a KX-56W. I can get the user manual for you if you still need it
Jul 02, 2013 | Audio Players & Recorders
Looking for schematic for Kenwood KX-55 stereo cassette tape deck
These dual cassette deck are rarely worth he effort to put repair time into. I checked Hi Fi Engine and they did not have anything. Is it worth a $100 repair bill? if not then look for a good solid single deck.
Mar 31, 2013 | Audio Players & Recorders
I´ve forgotten in what order I should connect my old (80´s) separate modul hifi system´s remote cables. It shuts down imadiatly when you try to start it with the remote. If I disconnect the...
I would have thought that it should go from the amp to the tuner,then the tape deck and finally the CD deck.
I'm suspecting that your tuner is faulty and thats whats causing the system to shut down
Aug 27, 2010 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Mower will run will not go foreward or backward
With transmission in neutral...start the engine and move the speed lever to highest speed and move it back to brake position, then shift the transmission into gear and move speed lever, this will fix the problem.
Apr 26, 2009 | Garden
Como conectar un ecualizador Technics SH-E51 a un amplificador Kenwood KA300
How do I connect my equalizer to my receiver?
There are two methods of connecting an equalizer, by either using the tape monitor or the main pre-in & output jacks. To connect through the Tape loop, connect the EQ L&R outputs to the Tape-in (play) jacks of the receiver, then take the EQ L&R inputs to the Tape-Out (REC) of the receiver. On the front of the receiver you will need to select the Tape Monitor to access the equalizer.To connect through main pre-out/ pre-in jacks, connect the EQ L&R outputs to the receiver main-in inputs (pre-in), then connect the EQ L&R inputs to the main out (pre-out)
Oct 05, 2008 | Audio Players & Recorders
Kenwood VR-6050 Receiver Logo
149 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
