Question about Microwave Ovens
When trying to popcornn the sense goes off and F3H comes on
Won't heat up and F3H comes on
  • Microwave Ovens Master
  • 9,047 Answers
F3H means you have a failing humidity sensor, but the first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can usually download it here.
You can usually find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on May 20, 2009
Kitchenaid microwave khhs179lss-0 has error F3H
Hi, F3H mean that Humidity Sensor Failure. You have to refer to the Tech Sheet and test the sensor.
Mar 23, 2011 | KitchenAid KHMS155L Microwave Oven
-F3H- WHAT DOES THAT MEAN- I was trying to cook frozen veg and it shut off and had -F3H- I canceled and tried it 3 more times and did the same thing-I have a whirlpool gold model #gh9185xlq-0
That means your humidity sensor is failing or has failed.
You can find helpful exploded view diagrams and order parts by entering your full model number (without dashes) or by part number (4393808) here.
Jan 10, 2011 | Microwave Ovens
F3H message; microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hgsshg
May 08, 2010 | Whirlpool Accuwave Microwave Oven
Started with lights on ceiling left side three tube replaced tubes replaced board now getting f3h code
You may not get an answer because your question is very confusing. You are asking about a Microwave and talking about lights on the ceiling which appears to be a florescent which you replaced 3 tubes on, but then you mention a board and a f3h? None of this really makes any sense to me. Maybe someone else may be able to understand but I cannot. Please elaborate in detail.
Feb 03, 2010 | Microwave Ovens
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Error code F3H on model GH5184XP
F3H is a humidity sensor error.
You may be able to clear the error by unplugging the oven for a couple of minutes. Then plug it back in, reset the clock and try again.
If it still has the error after a reset, please write back so we can give you another suggestion.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 18, 2008 | Whirlpool Microwave Ovens
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Microwave Ovens Logo
402 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
