Question about Acer Aspire 5315-2713 Notebook
Clnpwd.exe - Acer Aspire 5315-2713 Notebook
Spcmd.sys
The file "spcmd.sys" is known to be created under the following filenames: %System%\cc.sys %System%\dboy1.sys %System%\g3i2ll.sys %System%\setuplk.exe %System%\setuplk.sys %System%\spcmd.sys %System%\tencent.sys %System%\zzjkxs.sys %Temp%\xpanxionvirus\a1.exe %Temp%\xpanxionvirus\a2.exe %Temp%\xpanxionvirus\tmd.exe %Temp%\xpanxionvirus\tmd1.exe %Temp%\xpanxionvirus\tmd2.exe %Temp%\xpanxionvirus3\boot.exe %Temp%\xpanxionvirus3\cc.exe %Temp%\xpanxionvirus3\s.exe %Temp%\xpanxionvirus3\sc.exe %Temp%\xpanxionvirus3\se.exe %Windir%\a1.exe %Windir%\a2.exe %Windir%\s.exe %Windir%\se.exe %Windir%\tmd.exe %Windir%\tmd1.exe %Windir%\tmd2.exe c:\boot.exe c:\cc.exe c:\sc.exe Go to this link for more info http://www.threatexpert.com/files/spcmd.sys.html it is said to be of no threat.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Computers & Internet
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
I recently did a repair on windows xp and was wondering did everything go well? Here is my report: Logfile of Trend Micro HijackThis v2.0.2 Scan saved at 6:22:26 PM, on 3/23/2010 Platform: Windows XP SP3...
Apart the fact you have way too many programs on autostart, that there are still traces of the infection left and you are running a pirated OS, no.
Mar 24, 2010 | Acer Aspire 3000 Notebook
Be.tmp.exe application error. the instruction at "0x0040c173" referenced memory at "0x0040c173". the memory could not be read
This should all be done in safe mode and with system restore turned off for now.
This is a virus and You need to run your antivirus scan and remove what it finds,Run a cleaner program such as Ccleaner
Hit Ctrl+Alt+Delete and open the task manager,Under the process tab find and end task on tmp.exe and/or BE.tmp.exe.
It is a process belonging to an advertising program by 123bar. This process monitors your browsing habits and distributes the data back to the author's servers for analysis. This also prompts advertising popups. This process is a security risk and should be removed from your system.
%FontsDir%\nwlnkfwd.exe %FontsDir%\nwlnkipx.exe %FontsDir%\nwlnknb.exe %FontsDir%\nwlnkspx.exe %FontsDir%\nwrdr.exe %FontsDir%\oprghdlr.exe %FontsDir%\p3.exe %ProgramFiles%\internet explorer\keymaker.exe %ProgramFiles%\outlook express\keymaker.exe %System%\1025\zipfldr.exe %System%\1028\zipfldr.exe %System%\1028myztx.exe %System%\1031\zipfldr.exe %System%\1033\zipfldr.exe %System%\1037\zipfldr.exe %System%\1041\zipfldr.exe %System%\1042\zipfldr.exe %System%\1054\zipfldr.exe %System%\2052\zipfldr.exe %System%\3076\zipfldr.exe %System%\3com_dmi\edb.exe %System%\3com_dmi\edb0000a.exe %System%\3com_dmi\edb0000b.exe %System%\3com_dmi\edb0000c.exe %System%\3com_dmi\edb0000d.exe %System%\3com_dmi\edb0000e.exe %System%\3com_dmi\zipfldr.exe %System%\catroot\zipfldr.exe %System%\catroot2\{127d0a1d-4ef2-11d1-8608-00c04fc295ee}\tmp.exe %System%\catroot2\{f750e6c3-38ee-11d1-85e5-00c04fc295ee}\tmp.exe %System%\catroot2\tmp.exe %System%\catroot2\zipfldr.exe %System%\com\zipfldr.exe %System%\dhcp\zipfldr.exe %System%\directx\zipfldr.exe %System%\dllcache\zipfldr.exe %System%\drivers\disdn\ws2ifsl.exe %System%\drivers\etc\atmlane.com %System%\drivers\etc\atmuni.com %System%\drivers\etc\audstub.com %System%\drivers\etc\battc.com %System%\drivers\etc\beep.com %System%\drivers\etc\bridge.com %System%\drivers\etc\cbidf2k.com %System%\drivers\etc\ws2ifsl.exe %System%\drivers\ws2ifsl.exe %System%\drivers\zipfldr.exe %System%\export\zipfldr.exe %System%\grouppolicy\adm\gpt.exe %System%\grouppolicy\gpt.exe %System%\grouppolicy\machine\gpt.exe %System%\grouppolicy\user\gpt.exe %System%\grouppolicy\zipfldr.exe %System%\ias\zipfldr.exe %System%\icsxml\zipfldr.exe %System%\ime\zipfldr.exe %System%\inetsrv\zipfldr.exe %System%\keymaker.exe %System%\macromed\comadmin.exe %System%\macromed\comempty.exe %System%\macromed\comexp.exe %System%\macromed\edb00017.exe %System%\macromed\res1.exe %System%\macromed\res2.exe %System%\macromed\tmp.exe %System%\macromed\zipfldr.exe %System%\microsoft\zipfldr.exe %System%\msdtc\msdtc.exe %System%\msdtc\trace\msdtc.exe %System%\msdtc\zipfldr.exe %System%\mui\0418\ftdisk.exe %System%\mui\0418\gm.exe %System%\mui\0418\gmreadme.exe %System%\mui\0418\hgfs.exe %System%\mui\0418\http.exe %System%\mui\0418\i8042prt.exe %System%\mui\0418\imapi.exe %System%\schost.exe %System%\services32.exe %System%\spool\drivers\w32x86\3\mouclass.sys %System%\spool\drivers\w32x86\3\mountmgr.sys %System%\spool\drivers\w32x86\3\mqac.sys %System%\spool\drivers\w32x86\3\mrxdav.sys %System%\spool\drivers\w32x86\3\mrxsmb.sys %System%\spool\drivers\w32x86\3\msfs.sys %System%\spool\drivers\w32x86\3\msgpc.sys %System%\syskey_dll\sysupdate.exe %System%\system\system.exe %System%\tmp.exe %Temp%\5.exe %Temp%\70554keygen1.exe %Temp%\guqf296\keymaker.exe %Temp%\ixp000.tmp\efubtgis.exe %Temp%\ixp000.tmp\key_gen.exe %Temp%\ixp000.tmp\keygen.exe %Temp%\ixp000.tmp\keymaker.exe %Temp%\ixp000.tmp\tmp.exe %Temp%\ixp000.tmp\tvonuaek.exe %Temp%\ixp000.tmp\zwwltphz.exe %Temp%\ixp001.tmp\keymaker.exe
You should also download and run Spybot search and destroy and delete what it finds.
If
May 21, 2009 | HP Compaq Presario V3000T Notebook
Windows Freezing
Boot the system in safe mode
1.) restart the system
2.) pump the F8 Key until a screen comes up with different options
3.) select safe mode,
Try right clicking there and see what happens,, I,m guessing here this is a result of damages done by a previoulsy removed virus (GUESSING) it is possible that the same one could have been shard by all 3,,
I'd advise you'd uninstall norton and use the new avg free
www.free.grisoft.com
Let me know what hgappens and we can tgake this a bit further
Jul 14, 2008 | Microsoft Windows XP Home Edition
",.exe" (comma.exe) causing a problem
Its your OS affected by virus..
Mar 04, 2008 | Computers & Internet
Acer Aspire 5315-2713 Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
