Question about Samsung HL-T5687S Television
Has sound but No picture HL-t5687s
No picture
2 Suggested Answers
SOURCE: when I turn on my
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Posted on Nov 22, 2010
Tv is on but no picture no sound
LED power supply board behind access panel on side of TV back can cause this problem
Nov 27, 2013 | Samsung HL-T5687S Television
Lines Picture Vertical
It sounds that the T'Con board has the fault. Check the LVDS cable, that connect in between T'Con board and panel for any loose contact. Re-seat it once, and check. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong.
May 05, 2013 | Samsung HL-T5687S Television
Our picture disappears on our DLP HL-T5687S
Check this site to get more details about the faults to DLP TVs. Check it by search to your brand name and model number to its search box. Might be a lamp problem. Not sure. Check this link.
Jan 23, 2013 | Samsung Televison & Video
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
Nov 09, 2010 | Samsung HL-T5687S Television
Hi. I have a two-year old 56 inch HL-T5687S -- I have sound and picture, but then picture turns black and sound keeps playing . I turn off TV, wait a bit, and TV pic comes back on... then black after 2-15...
These problems are the cause by those 2 long LCD inverter boards are dying.These 2 long LCD inverter boards,help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay,com to buy those 2 refurbishes long LCD inverter boards for the replacement.Replaced these 2 long LCD inverter boards,should solved ur problems,u having.
Sep 10, 2010 | Samsung HL-T5687S Television
Green Picture
Sounds like you are not getting a red in your feed. Have you check the feed into your tv or if the cables are having a problem?? check it and let me know........
May 27, 2010 | Samsung HCN4226W 42" Rear Projection...
I have a HL-T5687S DLP TV. Since yesterday, my tv
right side push button stick ...check and open stick button
Nov 07, 2009 | Samsung HL-T5687S Television
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
Samsung HL-T5687S Television Logo
Jerry Greenberg
Jerry Greenberg
