Question about Philips Televison & Video
Philips 55pfl5907/f7 will not turn on
The TV will not turn on. The receptacle and the power cord work just fine. I called the service number on the side of the TV and was told to unplug it press the power button 20 times and plug it back in and turn on. (static reset) This did not work. The TV is less than two years old.
  • 8 Answers
SOURCE: power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Posted on Aug 21, 2008
SOURCE: 37LC7D, screen blank, cannot power off manually or w/remote
Hi, I would buy your TV
Posted on Dec 14, 2008
funkengruuve
SOURCE: My Philips 19pfl3403d/f7 wont turn on without unplugging first.
just call philips and they will send you a new t.v.! it isn't a recall, that would be bad publicity!! i spoke with a philips representative yesterday concerning my 'possessed' television. a gentlemen informed me that philips has a 'rapid replacement program' for the described 'possessed' t.v. set. simply provide model and serial numbers, time and place of purchase, then provide street address for fed-ex delivery. approximate time of arrival is 10-15 days. you are directed to package and return the old set to nearest fed-ex pick up site. i am super excited that i took the time to call philips support. i think that i spent a total of 10 minutes on the telephone; it was time well spent. oh yea, here's the number!
Speak with a Philips representative
1-888-744-5477 Monday - Saturday 8:00 am - 11:00 pm EST Sunday 9:00 am - 6:00 pm EST Excluding major holidays
Posted on May 10, 2009
  • 10 Answers
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
Posted on May 23, 2009
dave1645
  • 834 Answers
SOURCE: My polaroid TV will turn on but there is no picture or sound
blown caps in the power supply a 470m at 16 volt cap it will be puffed up
Posted on Sep 18, 2009
Testimonial: "You were right. It was blown 1000uf caps. Great job. Thank you very much"
Philips 42PFL3704D/F7. Why does it keep restarting?
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Oct 9, 2012 - 5 posts - ‎2 authors
Philips 42pfl3704d/f7 power reset when HDMI, USB, or cable attached ... or Cable TV to unit the power resets, philips screen comes on and keeps on resetting. ... I tried a cable to the tv without the box and I do get picture.
Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV
www.amazon.com/Philips-42PFL3704D-F7.../B001LP...
Amazon.com, Inc.
Rating: 3.3 - ‎50 reviews
Amazon.com: Philips 42PFL3704D/F7 42-Inch 1080p LCD HDTV: Electronics. ... Will do all I can to prevent others from getting ripped off by Philips. ... came up every few weeks and would take an hour or so of reset before working properly.
Visit the support page for your Philips LCD TV 42PFL3704D ...
www.philips.ca > philips > Televisions > 3000 series
PhilipsFind support for your LCD TV 42PFL3704D/F7. ... How do I output sound from myPhilips TV to external audio devices such as Home Theaters, Soundbars, AV ...
42" Philips 42PFL3704D/F7 LCD TV WON'T COME ON - A
Dec 29, 2015 | Televison & Video
Why my 42pfl5907 tv will not turn on?
Plug it in.
Check your internal fuses.
Then check the power cord for continuity.
Nov 01, 2014 | Philips 42PFL5907/F7 42 Class Led Lcd...
I have a Philips hdtv model # 39PFL2608/F7, it worked fine one afternoon and then when I tried to turn it on that night there was no picture, no sound, no light on the front only a high pitch whinning
Most whining sets have a problem in the power supply. A transistor under abnormal load or frequency can whine. I would turn it off, and if you are not inclined to fix such stuff, haul it to a shop. If inclined, search for a service manual, or remove the back and find the board with the power cord socket, get the numbers and search ebay and the web for a replacement board. You can also search for hints using the model number.
The whine is not good, and will eat the transistor if left in that condition. Most bad capacitors will bulge at the top when failed and you can replace with low ESR capacitors 105C rated of the same volts/farads/dimension and maybe fix the supply yourself.
Oct 27, 2014 | Televison & Video
How to fix 40pfl4908/f7 will not turn on
My philips tv no 40pfl4908/f7 has a white flashing light and the tv does not turn on
Mar 15, 2014 | Philips 40PFL4908/F7 - 40 LED 1080p HDTV...
Philips 32PFL3505D/F7 32-Inch LCD HDTV keeps turning off when I turn it on
very common failure on this tv is electrolytic capacitors failing on the power supply, the module that your power cord plugs into. The Caps can appear to have swollen tops, replace with same type or slightly higher working voltage. Observe capacitor polarity when installing new parts. Probably 1000 mfd @ 16V could be 1000mfd @ 25V.
you need soldering skills to repair the parts in question.
Mar 03, 2013 | Philips 32PFL3505D 32 in LCD TV
Where is My Philips 32pfl3505d f7 LCD TV fuses
I assume you are referring to the ac fuse, it is located on the power supply board. Just follow the ac power cord and it should lead you to it. If your set doesn't have a built in power cord, the fuse will be next to the power cord connector.
Sep 01, 2012 | Philips 32PFL3505D 32 in LCD TV
Tv will not turn on
If the LED lights up and turns green or stays red then you have a power supply problem
Dec 08, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Televison & Video Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
