Question about Troy-Bilt Garden
Leaks gas out of carb won't stay runninng - Troy-Bilt Garden
  • 163 Answers
It sounds like your float is sticking open. You could try to remove the carb and clean or rebuild. I always find it better to replace carb and clean out old gas tank really well. Hope this helps.
Posted on May 17, 2009
Brigs n straton pressure washer won t stay running unless you put or keep starting fluid in in
Loosen the carb bowl nut until it begins leaking into the shallow clear glass bowl you placed beneath it. It may take a minute to have drained the water out of the bowl and another minute or so to get some more from the gas tank. With the glass bowl you will be able to see the water in the bottom and gas floating on top of it. When you see the gas on top then tighten the bowl nut and try to crank. (Choking helps draw out water still in carb) Return gas collected. to tank but do not let the water go back in.
Sep 12, 2013 | Psi Blue Max 2200 High Pressure Gas Power...
New filter new fuel pump won't stay running
Well your engine has a carb, so it could be dirt in the carb, or a vac leak, or several other possible causes.
Does the choke close when the engine is first started ? Have you checked the fuel line to see if the pump is providing gas ?
Apr 25, 2013 | 1987 Dodge Raider
Ryobi 780 r won't stay running
replace the carb. You are flooding the engine because there is an internal leak that a carb kit won't fix allowing the gas to continue to flow
Feb 01, 2013 | Garden
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
2006 Honda Shadow won't start. Gas tank filled. Sat 8 mo. Gas leaked out but not into engine.No sign of external leak. into
1. Drain the gasoline.
2. Remove the carb bowl(s) and turn on the petcock to drain the fuel in the lines.
3. Clean out the carb bowl(s) and replace.
4. Refill with gasoline, add 1 oz of Seafoam fuel system cleaner (I'm not a sponsor, I just haven't found anything better) to each gallon of gas. This will stabilize your fuel as well as do a great job of cleaning out the carb(s).
5. Try to start it.
If it still won't start, begin the standard troubleshooting procedure by first pulling a spark plug and turning it over to ensure gas is getting to the cylinder. If so, replace the plug, hold the plug wire slightly away from the plug and turn it over to ensure a spark jumps between the wire and plug. If so, it starts getting complicated. Buy a manual for the bike if you don't have one and follow the troubleshooting steps there.
Jul 24, 2012 | 2006 Honda Shadow Spirit 750
Pw50 leaks gas
Hi, Anonymous "ABSOLUTELY" and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
PW50 carb won stop leaking fuel
Yamaha PW 50 checking carb
https://books.google.com/books?id=ozV8-Aer4N8C&pg=PA84&dq=pw50+manual&hl=en&ei=TCS2TcbdJ4PW0QG0z9jmDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CGUQ6AEwAA#v=onepage&q=pw50%20manual&f=false
OEM parts for Yamaha
Yamaha PW50Y Owner Manual
Jun 01, 2012 | 2005 Yamaha PW 50
1986 Toyota p'up starts, but won't stay running once i left off gas pedal
first i would look for a vacuum leaks get it as close to idle as you can when cold and spray carb cleaner around and also check to see if the egr valve is stuck open this will act as a vacuum leak but not detect as one spraying carb cleaner around carb cleaner with change the engine speed near a vacuum leak
Apr 18, 2012 | 1986 Toyota Pickup 4WD
Toro recycler mower won't stay running
take apart the carb float and clean it out, then take apart the rest of the carb and spray cleaner through it. sounds like you might have some old gas turned to jelly in your carb thats plugging it too much for the typical pressures inside the carb to **** through
Jan 25, 2012 | Toro Power Lawn Mower
19e412-0134-01 won't start. gas leaks out air
The float is stuck on the carb flooding the engine and leaking gas out of air filter. Remove the float bowl after the gas is turned of or drained. Thoroughly clean carb And bowl with carb cleaner. Reove the float {very carefully} if it is copper, shake it. If you here fuel in it then it is no good. If not then clean everything and reassemble. If it needs to be replaced, most small engine repair shops will have your parts.
Aug 28, 2011 | Porter Cable BSI550 W 5,500 Watt Generator...
Weedwacker won't stay running
replace the fuel lines and check that the filter in the fuel tank( its on the end of the intake fuel hose) is clean. If there is an air leak somewhere in the old lines it will cause the trimmer not to get enough gas.Then clean the carburetor with carb cleaner- take the carb off by removing the air filter first then undo the two nuts holding on the carb and take off accelerator cable remembering which hole it came from. spray the hole carb with the cleaner on the inside and outside then soak it in the cleaner trying to get any dirt out. put it back together and it should start...if not you might need a new diaphragm in the carb.
Jun 20, 2011 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
233 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
