Question about GE Spectra JBP78 Electric Kitchen Range
How to remove top of GE JBP95T0F1WW to replace heating element? I purchased a replacement heating element, but can't figure out how to get the top off of the stove.
  • 3 Answers
If you are talking about the surface element it just slides out. You can lift the stovetop straight up by pulling up on the front of the top. if you need to replace the connector which has a sheet metal bolt
Posted on May 21, 2009
    Problem Solver:
  • 18 Answers
You may have to get to the element from under side
Posted on May 17, 2009
Remove and replace heating element in GE Dryer
Not enough info! what is model number?
GE dryers has many models and each one has different procedure to remove heating element
Apr 20, 2014 | GE Washing Machines
The dryer operates but does not produce heat. i think it is the heating element but i can not get in to the back of the dryer to check. i would like to get a service manual so i can check the element
1 Unplug the power cord from the electrical socket.
2 Remove the screws located around the edges of the back panel of the DVLR223 dryer. Move the back panel away from the cabinet.
3 Push the idler pulley away from the belt to loosen the belt tension. Remove the screws on the panel behind the dryer drum. Remove the panel.
4 Remove the four screws located on the underside of the top panel. Lift the top panel off of the cabinet.
5 Lift the drum up through the top of the cabinet and set it aside.
6 Unplug the electrical wires connected to the heating element assembly. Remove the old heating element from the DVLR223.
7 Insert the new heating element where the old one was previously located. Plug the electrical wires into the heating element assembly.
8 Replace the drum inside the dryer cabinet. Replace the top panel and the four screws that go on the underside of it.
9 Replace the panel behind the drum. Replace the screws that hold it in position.
10 Reposition the back panel onto the DVLR223. Replace the sheet metal screws around the perimeter of the back panel.
Jun 19, 2011 | GE DVLR223 Dryers
How do I replace the heating element on a ge
First unplug your dryer. Open the door and you will see a couple of screws holding the front to the top of the machine. remove these screws and the top will come off. there are 2 more screws at the top and on the inside of the front panel. remove one on each side and the front will come off. you must then remove the belt from the motor and pully. this will allow you to pull the tub out and you will see the elements at the rear of the machine.
Jul 19, 2010 | GE DWSR463EGWW Electric Dryer
Broken Glass on Cooktop
Ouch. The glass top does have to be replaced but I just ran the partial model number on your range and if you're at the comp. I hope you are sitting down. Replacing it not bad. Purchasing tho is rediculous. Retail suggested price just for the top is 600.00. Rediculous pricing but GE is like that sometimes. Sorry but repairing the glass is not possible and getting it from a glass shop isn't either. Sorry for the not so good news. Rick
Mar 01, 2010 | GE JSP57 Electric Kitchen Range
How do i replace oven heat element? It is a GE Profile electric glass top range, model # JBP90WV2WW serial # ZM203767G
Turn off the power to the oven. Remove the oven racks. Unscrew the element retaining screws on the rear wall. Carefully pull the terminals out of the back wall of the oven. Remove the wires. Place the wires on the new element,slide it into the opening,tighten the screws,replace the racks,turn on the power.
Nov 12, 2009 | GE Ovens
How do I change the top heating element on a G.E. Profile double oven JKP54G0P1BG
the heating element should have 2 screws in, when removed pull the element towards you then pull off the 2 wires,replace in reverse order.
Sep 30, 2009 | GE Profile JTP18 Electric Single Oven
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Will not dry clothes GE Model # DBLR333ET1WWW
hi. thanks for the question.First check the fuses in fuse panel 2- 30 amp fuses. replace them. 1 could be out.If the fuses are now ok and still no heat. The element is located at the back of the drum. To replace. Open the door 4 screws on the top lip remove. Lift top. 2 screws on inside of front panel. remove .Pull drum out remove belt, pull drum out . look for broken coil if so replace element .Thanks the appliance doc
Sep 29, 2008 | GE Dryers
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
Dec 18, 2007 | GE JKP20 Electric Single Oven
GE Spectra JBP78 Electric Kitchen Range Logo
376 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
