Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Our friend gave us his sony 2005 52 inch tv and we know NOTHING about it. I turned it on this morning and after 30 second it just turned itself off, and will not turn back on. The lamp light below the power button just started blinking red.
techman
  • 3130 Answers
SOURCE: Sony Trinitron KV-27S46
There is a problem in the sweep section of the set. The Horizontal sweep power supply most likly. there is nothing a layman can do as it will involve troubleshooting the solid state circuit. please find a trainded tech to assist you in this repair.
Posted on Sep 22, 2006
SOURCE: set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Posted on Aug 08, 2008
SOURCE: blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Posted on Sep 08, 2008
  • 61 Answers
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
Posted on Oct 15, 2008
welcomejee
  • 10594 Answers
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Posted on May 18, 2009
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Not getting any sound from tv. when turned on this morning it gave sound for a second then stopped. reset tv, reset cable box, nothing.
Hi friend,,,
welcome to fixya
Did you checked whether any high voltage caused the problem,if it is then check the connection to speakers or check the connectors from resistors,ok..
if you know how to check then try it or else please it is better to go to a technician/////
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
My Toshiba 57H84 has stopped picking up my PS3 through HDMI
try holding your finger on the power button(next to disc eject) for 5 secs
May 24, 2009 | Sony PlayStation® 3 (60 GB) Console
TV keeps shutting itself off!!!!
I think the problem with the remote control it malfunction take the remote control away from the tv
and test the tv
I had the same problem and one time the tv came on by itself
now i took the remote control away and testing the tv
now for 15 min. so far so good
try it and let me know
or call sony 1--800-222-7669
email me dnae@cox.net
thanks
Dave
May 24, 2008 | Sony FD Trinitron KD-34XBR960 34" TV
Sony turns off and on by itself
The lamp almost always causes this problem. The Sony lamp when about to fail will cause the unit to power off interminttently. Replace the lamp and this will correct the problem.
Jan 21, 2008 | Sony KDF-E42A10 42 in. LCD Television
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
122 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
