Question about Bass Pro Shops 30 Quart Propane Turkey Fryer
Can not get gas to flow from propane tank on turkey fryer from bass pro shop
How do I troubleshoot my fryer when I cannot get it to start?
In order to turn the knob to the pilot position you need to push the knob in slightly and then turn. Once the pilot position on the knob is lined up with the indicator on the valve, you can push it in and gas will flow to the pilot assembly.
Feb 28, 2015 | American Range AF45LP Deep Fryer
Turkey fryer won't start
Yo! the Dang pan has to be filled and on the burner which makes contact with the auto shut off sensor that is measuring the temp of the pan. The weight of the filled pan holds that Lil temp sensor down and allows the gas to continuously flow as if you were holding that Lil red button. So after hours of trying to light it without the pan you should find that it does work with the filled pan on the burner holding the red button, stick a match in the hole and let the button go and watch the blue flames flow. My gripe now is that it shuts off after the oil temp reaches 250 to 260 degrees then you have to reignite. Oh yeah my 10lb Turkey was crazy tasty.
Nov 21, 2012 | Brinkmann 815-3786-0 Turkey Fryer
Bass pro turkey fryer wont stay lit
wire around timer or set something on button so runs all time. but also set a cheap alarm or use one on cell phone to remind you time is up.
Feb 25, 2012 | Bass Pro Steamer/Fryer Combos Turkey Fryer
Have a older 11 piece eastman outdoors fryer ptg no 90320 hose and reg assy needs replacement
try candain tire they do spares you may find what you need there or calgary bbq centre or bass pro shop
Aug 16, 2011 | Eastman Outdoors 37045 Turkey Fryer
Connecting the LP Fryer to the propane tank
The gas valve has a regulator on it....but there must be a regulator at the tank that steps it down from tank pressure to operating pressure. Operating pressure for LP is less than 1/2 psi. If you are using this for a trailer....a 40 lb tank would be best.
Tom
May 25, 2010 | American Range AF40 Deep Fryer
Tried to use my turkey fryer and could only get a yellow flame. Never had a problem getting that nice blue flame before. Do I have a reg problem or a burner prob??
Check your propane tank first; is it getting close to being empty? Check where the hose connects to the burner, there should be an air adjustment there; it looks like a rotating disc with two big holes on either side, this is turned when the burner is lit to adjust the amount of air mixing with the gas. If it's all the way open, you have a yellow flame, if it's closed all the way you have a blue (but weak) flame. Try adjusting that and if that doesn't work, try a different regulator...it is rare a regulator could cause this but it could cause it; just use that as your last resort.
Dec 03, 2009 | Cajun Injector Deluxe (30 Qt) Turkey Fryer
How do I attach the hose to the cast iron burner,do I just thread the brass fitting to the cast iron burner or is there something missing
Hello. Yes, the brass fitting goes on to the burner. At the other end of the hose is the valve and the larger connector for the propane tank. Enjoy your turkey! Regards, Joe
Nov 23, 2009 | Bayou Turkey Fryer Kit - 9195 Turkey Fryer
Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Oct 31, 2009 | Thermos 0210-1309 Turkey Fryer
IGNITION WITH PROPANE DEEP FRYER
this is a safty feature turn and hold pilot light untill lite then the gas should flow..but only after pilot is lit for 30 seconds
Nov 27, 2008 | Kitchen Appliances - Others
Bass Pro Shops 30 Quart Propane Turkey Fryer Logo
47 people viewed this question
Top Bass Pro Shops Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bass Pro Shops Kitchen Appliances - Other Expert? Answer questions, earn points and help others
