Question about Garden
Engine stopped running while cutting grass. Engine on a John Deere lawn tractor. Gas filter appear to have no gas in it. Gas tank was half full. Engine had been running for approximately 1/2 hour prior to problem.
  • 323 Answers
You may have accumulated a little trash, perhaps a little water, and general gunk in the bottom of your gas tank. Either that or a bad fuel pump.
I'd get a new fuel filter, clear plastic kind, and if you have an air compressor or access to one, block the opening of the gas tank, blow compressed air into it, and see if ugly stuff comes out of your tank.
Watch out for blow back out of the tank. I use an old natural sponge like you'd wash a car with, mash it down hard agaunst the openingm and put the blow gun down into the middle. It will take a little while for the pressure to build up enough to blow the stuff out.
Make sure you have the hose down in a can or plastic jug. If the gas comes and freely and is clean, suspect the fuel pump. The filter should have plenty of gas running through it.
Sirwriter
Posted on May 18, 2009
John Deere 160 lawn tractor.
May have online fuel filter in line, need to check. Also could be wear in throttle shaft or housing in carburetor.
Aug 12, 2017 | John Deere Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
John deere tractor wont take up throttle
try some lucas gas treatment. may have something to do with the float in carb. Might replace it and try.
Jun 20, 2013 | Garden
John deere lt155 lawn tractor shuts off when it gets hot while mowing, could this be electrical?
I had a similar problem lasy year.
Try this:
As soon as the machine seems to be stalling, loosen the gas cap.
If the engine continues to run, clean the gas cap vent hole(s).
Gary
Jun 26, 2011 | John Deere Garden
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
475x runs out of gas during normal ops. Leave key
the gas cap quit venting the tank...it's causing a vacuum that the pump can't draw fuel against...to check, loosen the cap and cut some grass...if it works, clean out the hole in the top of the cap...if not replace the pump..
Apr 18, 2010 | Garden
Have a John Deere L111 lawn tractor with running problems
I had the same problem and I figured out that it was the small hole on top of the gas cap. There is a vent hole on the top/middle and this got plugged with debris and caused a vacum in the gas tank which caused the engine to sputter and kill. Good luck!
Apr 12, 2010 | John Deere 1:16 Scale H Tractor with hay...
Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
John deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
May 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
190 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
