Question about Canon PowerShot A85 Digital Camera
Monitor pink line at top.but images very blurry tried 5 mem cards all the same outcome.
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 17, 2009
Cameras on monitor look blurry Qs408
Note this system uses VGA quality images so will not be as sharp has HD cameras. Also, due to the number of cameras, you frame rate may suffer. If you are not using a flat panel monitor, try that to see if the quality is better.
Feb 04, 2014 | Digital Peripheral Solutions Q-See...
My Acer AL2416W is showing a tint of pink in all images I try to display, I have changed the cables with no change. I have taken the monitor to a new computer and it works fine ( no pink at all ). Why is...
The problem is in your old computer, the video graphics card is faulty, you mentioned the monitor was hooked up to the new computer and worked fine.
Apr 17, 2012 | Acer AL2416W Monitor
My screen has become blurry but you can still make the words out,it started with a thick blue line now its got worse
Hardware failure. To find out which part has failed - the screen or the video card - just try to use another monitor or tv . If the image is the same then it's the video card, if it's good it's the monitor.
Jun 06, 2011 | Acer (9005210464), (64 MB) Graphic Card
I have an Onkyo TX-SR702E that no longer projects blue when I try to play a DVD. It is not the DVD player because we have tried two different DVD players with it, and the outcome is the same. Films have...
Well, although it may be the receiver, it may may be your video monitor. I looked over the manual on line for your unit. The connections to your receiver going to your video monitor (i.e. projection, or flat screen, etc. are of a "pass-through" type specifically for the video images. That is not the case with the audio side. In other words your Onkyo passes (or patches through) video signals without altering them. It is so that you don't need to a lot of remote controls to enjoy being entertained.
It could be a problem with the mechanical relays that do the switching or it is directly in the video monitor or TV.
Here is a simple diagnostic procedure for checking this. You may have already done this. Simply take video (yellow) single cable and yellow output from the DVD player and connect it to the yellow Video one or Video 2 inputs directly on your Monitor or projector and see if it is showing a pink image or a natural one. You don't even have to connect up the audio.
If it is still pink. It's the the video monitor, (TV)
If the color is correct, then it's the receiver switching circuitry . Considering the base quality of the receiver, it is worth servicing.
If you have any question feel free to get back to me through this site.
Here is a link to your owner's manual.
http://filedepot.onkyousa.com/Files/own_manuals/TX-SR702,602_En_C.pdf?CFID=1396296&CFTOKEN=48521992&jsessionid=f030d40da2752b8d3dcd3b1b40fe67769c1f
I hope I've helped you,
Best Regards,
Mark
Jan 21, 2011 | Onkyo Audio Players & Recorders
My monitor in blurry and has a pink tinge to it. I can click a button on the side and bring up a box that says brightness, contrast, sharpness,etc- but I can't move off the brightness to change to other...
Use the LEFT and RIGHT arrows (or UP and DOWN arrows)
on your monitor to move between the different items (brightness, contrast, etc.)
However, "pink" is generated when your computer tries to generate "white" (mixing red, blue, green) but one of these 3 "primary" colours is not being generated.
Try your monitor on a different computer, to see if the "pink" is due to your monitor, or due to the video-card on your computer, or due to the data-cable between your monitor and your computers.
Dec 31, 2009 | Addlogix Computers & Internet
Samsung LCD 19" monitor problem
Does the monitor plug into a card or the motherboard socket?
Mar 25, 2009 | Samsung SyncMaster 920N 19" LCD Flat Panel...
Scan and copy lines
using PRT screen and menu find clen function and try if this feature will fix the issuw.
Change the cartridge if no results.
Jan 30, 2009 | HP LaserJet 3050 All-In-One Printer
My pictures and the lcd screen come out blurry and pink, with horizontal lines across I have a Sony CyberShot DSC-T1 Digital Camera with 5 megapixels and 3x optical zoom I got in 2004. When I take...
Camera symptoms shows bad CCD Imager in camera and this part needs to be replaced.
Sony has announced free of cost repair scheme for such problem in DSC-T1 models. Please click Sony Support for details.
Thank you.
Sep 20, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Blurring of images and text
mt, the 6 to 8 lines you were seeing were most likley the prelude to the end of the monitor. If the problem only occurs when the screen saver comes on then I could say the driver maybe being corrupted by a certain screensaver picture or program. When the monitor warms up to a certain temprature the electronics start to fail. You may want to turn off the monitor while your not right in front of it to cool it down and prolong its use.
Jan 27, 2007 | LaCie Electron 22" CRT Monitor
Canon PowerShot A85 Digital Camera Logo
132 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
