Question about Hayward SAND FILTER, PRO SERIES
Pool filter is not filtering the dirt out of pool.
Already checked the gasket on the vari-flow valve. didn't seem to make a difference. back-washing was also done. will replacing the sand make any difference?
  • barnyard_23 May 25, 2009
    I have tried the backwash and I have super clorinated my pool and when I vaccum you can see the dirt go back in the pool any ideas?
  • 110 Answers
Will replacing the sand make any difference?
Only if you have very dirty sand. -But seeing as you have backwashed it - I would say it will help but not fix prob.
Have you got all pipes in right holes?
Did you put head stock on right way?
Posted on Jul 07, 2009
How do I check the backwash valve?
Is it a vari-flow valve?
If so with the pump off set the valve to "filter" then you can remove the screws on the top of the valve and remove the assembly. The gasket that usually goes bad is the "spider gasket", it looks like a pie-chart. Check this gasket for any tears or bends in the rubber, if you see any replace it. Turning the valve with the pump running will cause these gaskets to go out
Sep 10, 2013 | Hayward Pro Series 18" Above Ground Pool...
S210 discharge problem
If it is a vari-flow valve, this usually implies a bad gasket. With the valve set to "filter" and the pump OFF you can remove the screws on the top of the valve to check the gasket. It looks like a pie-chart, and usually called a "spider gasket". Check the gasket for tears or warps in the rubber, if you find any replace the gasket. A bad gasket will cause water to flow into different pipes. Turning the valve while the pump is running will cause these gaskets to fail
Aug 26, 2013 | Hayward Pool & Spa
Dirt passing through the filter
There is no oring from the lateral stand pipe where it plugs into the bottom of the multiport valve.
There is a gasket in the internal valve, commonly called a Spider gasket. Change that.
Jul 14, 2012 | Hayward SAND FILTER, PRO SERIES
I changed my sand in the filter last month, when I opened up the pool it was full of green algae, the filter is working but I haven't had to backflush since 2 days ago. The water is still extremely cloudy...
If the water is beginning to clear up, it doesn't sound like you have done anything wrong. You might just need to let your pool filter keep working. I would
a) make sure that your pH, chlorine, and alkalinity levels are correct. An inproper balance of chemicals might be causing the cloudyness.
b) Be sure Vari-Flo valve is set on “Filter” position.
c) Operate filter for longer periods.
d) Make sure that the flow rate through filter is sufficient.
e) Continue to backwash frequently.
Try this for a few days and let us know if you still don't notice a change.
May 24, 2010 | Hayward SAND FILTER, PRO SERIES
Hayward S180t filter w/ hayward sp 711 multiport valve. I removed to multiport valve to fix the spider gasket. I didn't think to mark so I could put the multiport valve back on. I need to know how to put...
Hayward 711A13 Vari flow valve. When I push down the handle to move valve into other settings the handle does not want to relock into the next setting. I have to manually pull up un the back of the handle and tap with my hand to get spring to retract. What can I do to lubricate this sping inside?
Apr 28, 2010 | Hayward SAND FILTER, PRO SERIES
How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
De powder coming back into pool water from filter
make sure your grids are properly seated and if you have a multiport valve, take it apart and make certain your spider gasket is in place and not distorted. That is the only other reason DE would return into the pool. If you have a slide valve, make sure your o-rings inside are in good condition and properly lubed.
Nov 01, 2009 | Hayward 48 Sq Ft Pro Grid Vertical Grid De...
When vaccum dirt, comes back in thru jets. \have a hayward filter
Do you back-wash your filter regularly?
Sound like dirt build up.
Jun 29, 2009 | Hayward SAND FILTER, PRO SERIES
Vari flow is on filter but dirt is passing into pool.
You can replace the spring inside if it is too loose, however you are unlikely to see damage on laterals. It only take a couple thousanths of an inch wear for them to allow sand and/or dirt past.
Jun 12, 2009 | Hayward SAND FILTER, PRO SERIES
My pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Apr 25, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
238 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
