Question about Element Electronics 40 in. LED HDTV
Hooked up new tv have no digital channels.it's a eleft406
Got new didital vizio modejE601-C3 today it is hooked up to cable but will not pick up digital channels and will only pick up 1 analol channwl3
if you have a cable hooked to it,then you need to pay for a cable tv subscription,you cannot get free digital channels on it,you shouldnt get any analog channels unless a station hasnt changed to digital,you need a cheap hdtv antenna to receive digital channels over the air.
May 25, 2015 | Vizio Televison & Video
No Digital Channels Detected
Jason, good you have narrowed down the problem. So tv 1 does not detect channels. Re-connet and try making sure all cables are properly connected.
Mar 03, 2014 | RCA LED55C55R120Q 55" 1080p 120Hz LED HDTV...
We have a Sanyo CE32DFN2-B digital television. Our region has completed the digital switchover today and now we cannot tune the TV into any channels at all. Is this because our TV is too old to cope with...
Ur tv have a big back like hunt back creature?Yes?This tv it is not a Digital tv.It is an old CRT tv-tube analogue design tv.This tv still will work and have a broadcasting incomming signal if it is hook up to a pay services tv like Satalites tv like Direct Tv,Dish Network tv,Timewarner or Cox Cables services and ATT U verise or Verizon Fio digital hook up.If u wanted to watch a switch over FREE OVER THE AIR DIGITAL incomming broadcasting signal for this tv it will not work alone,the tv must have be to hook up to a BOX that call a DIGITAL CONVERTER BOX than this tv will work for a FREE OVER THE AIR DIGITAL broadcasting tv channels stantions.This DIGITAL CONVERTER BOX are no longer on sale on regular Stores.Tries websites like Amazon.com,Ebay.com will able to buy these BOXES so call DIGITAL CONVERTER BOX.
Aug 17, 2011 | Sanyo Televison & Video
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
How do you hook up to the comcast digital unit to
tune your tv to channel 3 if you're coax cable, if you're using rca or component cable then tune your tv to the proper input on your tv.
Jun 26, 2009 | Apex Digital AD-1500 DVD Player
New TV doesn't register being HD ready during test TV stations do
Try going into the setup menu and make sure it is set to antenna then do a channel program. You don't need to wait for a test there are plenty of channels already there. Both digital and analog channels are still available so you will still a message that you are not receiving digital if you are putting it on an analog channel. The channel number has to have a dot(.) in it like 8.1, 24.1 If there is no dot you are on an analog channel
Mar 13, 2009 | Westinghouse Electric W1603 15.6 in. LCD...
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
HDTV converter box only brings in 3 channels
We have a pretty good signal when we use the antenna but when we hook up the converter box we get no channel weak signal no channels we have a amplipher on it it does not help .
Nov 22, 2008 | Insignia Digital-to-Analog Converter for...
TV will not get cable channels
If you have it hooked up to a digital box, it shouldn't matter if the TV is on cable or antenna mode. The only thing that matters is that the TV is on channel 3. Channels will be changed on digital box. Some newer TV's use input 1 or 2 or AUX for it to work. If I were you i would hook everything up and start playing with the channels going up and down until you get a picture.
Dec 28, 2006 | Orion1934 19" TV
Open Questions:
See all Element Electronics 40 in. LED HDTV Questions
Element Electronics 40 in. LED HDTV Logo
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
