Question about Photography
VistaQuest Digital Picture frame won't show all pictures I uploaded
Only a portion of the pictures will show on the frame. What do I do?
SOURCE: IQ Digital Picture Frame
I have an IQ Digital Photo Frame but the manual is in French I would like to be able to download the English version can anyone help please
Posted on Aug 05, 2008
  • 5 Answers
SOURCE: Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Posted on Dec 20, 2008
SOURCE: PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Posted on Feb 11, 2009
  • 7 Answers
SOURCE: SmartParts Frame SPX7E only allows me to load 165 photos
2 answers...
To remove a picture, connect the frame to your PC via USB. you should see the frame appear as a drive, in my case,
36972 (E:)
open the drive as Explore, you can now see the pictures, and delete what you no longer want.
you can download the software from
http://www.smartpartsproducts.com/content/support/optipix/index.php
Posted on Oct 05, 2009
SOURCE: IQ Digital Photo Picture Frame - Need Engish Operating Manual
http://www.gentec-intl.com/GentecInc/commodity/3101/manualE.pdf
Posted on Oct 20, 2009
Why do my pictures come out sideways
Turn them around in your laptop first and then transfer them. It is the screen resolution that is not compatible.
Jun 26, 2014 | VistaQuest 8" Digital Photo Frame
How do I select to use the internal memory on my photo frame?
www.vistaquestcorp.com/lang/en
Consider writing to them and get operating instructions.
Jun 23, 2014 | VistaQuest 8" Digital Photo Frame
Can't get any of my personal pictures to show up on the digital picture frame at all
Check the max resolution of you pic frame (800x600), you may have to resize your pics down in res until they display. Take one pic that will not display and reduce the size 6 or 7 times on a memory card.( ... Make it a litter smaller each time) Then load and show each one until it is displayed. You have found your target size...
Jan 04, 2014 | VistaQuest 8" Digital Photo Frame
I can't figure out how to re-orient some of my pictures to be right side up on my VistaQuest 8" Digital Photo Frame VQ0801W. I need to rotate some so they aren't on the side.
We use Picasa program to manage our pictures and videos. It's a free program and it works great. It should also help to fix the problem you have. Let me know if it helps!
Dec 27, 2013 | VistaQuest 8" Digital Photo Frame
I inserted a thumb drive with pictures on it and although they show on the frame, they do not show in the order that I numbered them in
The following advice is not specific to your model, but you have a common problem and the solution I suggest usually works for most makes and models.
Try renaming the files in the order you wish them to play as 001, 002, etc. If you do so without the leading zeroes then on some models of picture frames the filing system gets the images in the wrong order. Note that if you are uploading thousands of images then you may wish to start the numbering at 0001 instead. After renaming the files, re-upload them to the photo frame and you should find that they're OK. Depending upon your host computer's operating sytem you should be able to batch rename the files instead of laboriously renaming and saving each one individually.
Aug 21, 2011 | Quantaray 7-Inch Digital Picture Frame -...
How do I upload photos from my computer to the picture frame? The frame says PC Connection established. Remote is temporarily inoperative.
does the picture frame have an internal memory or accepts a memory card?
if memory card is accepted then try uploading images to the memory card and then inserting the memory card into the picture frame.
i hope this was helpful.
Dec 12, 2010 | PANDIGITAL (DPF802) Digital Picture Frame
How many pictures can the Kodak EasyShare SV811 hold at one time? I tried uploading around 30 picutres from my computer to my digital picture frame and only 17 of them uploaded. Did I try uploading too...
SV811 doesn't have a large enough internal memory thats why the picture capacity depends on the inserted SD card or if you transferre pics directly from the computer to display simultanously.
The frame should display as many as on the SD card.
Nov 30, 2009 | Kodak EasyShare SV811 (8858946) Digital...
The slide show will not show all the pictures on my memory card.
There should be no limits. However, please install the latest firmware on your frame and get it from www.kodak.com/go/downloads . Also, try a smaller memory card size and check if it has something to do with the card.
Apr 25, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Upload images to SD card
I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
Dec 18, 2007 | Nikon Coolpix 3200 Digital Camera
Photography Logo
29 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
