Question about Motorola Mobility S11-Flex HD
Doesn't charge no light, tried diff. charge cable, nothing works. headset is just dead
Why can't I turn on my Jabra sport after charging?
Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
May 23, 2014 | Jabra SPORT Earset
Red light flashing
I have the same problem and have been crawling all over looking and haven't found a thing...I think it means the battery needs replaced...I charged mine with a diff charger than what came with it and after a few days it started blinking whether its plugged in or not. Have you charged yours with a diff charger?
Aug 15, 2013 | LG HBS-700 Bluetooth Headset
Cant get it turn on
It likely that rechargable battery is not taking a charge any further or the contacts point of plug are damaged. Sorry to say "it's dead, Jim."
Jan 31, 2013 | Jabra BT350 Bluetooth Headset Headset
NOKIA C7 WONT SWITCH ON HELP!!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jul 26, 2012 | Nokia C7 (8 GB) Smartphone
I bought the plantronics voyager pro bluetooth headset two months ago and now it's dead. It's been working great for two months. When it's plugged into the wall for charging the red light is illuminated....
One thing you can try is to power down and then power the headset back up. The instructions are on the link below for the Plantronics Voyager Pro, particularly the page "Listen To The Voice."
Plantronics Voyager Pro User's Guide
If that doesn't help, then you have a bad processor in the headset. It's still under warranty so contact Plantronics at 800-544-4660 x5 x5538 for warranty service.
Good luck from Headsets Direct!
Apr 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
Light only lights up while charging
are you pressing and holding the button for 3 seconds until it flashes 3 times as that is howyou turn it on and off, not by simply pressing the button and then letting go.
Jun 24, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility S11-Flex HD Logo
32 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
