Question about Dell Dimension E310 PC Desktop
Drive 1 and 3 not found
Black screen upon start up
  • Nelson Olaso
    Nelson Olaso May 11, 2010
    you min u cant see any booting system,like bios or windows/OS?..thanks
First off be sure your drives are enabled in your bios
Posted on May 17, 2009
Power connection to computer came out during shutdown yesterday. Today, turning on, it will not boot up.
You are going to need a clean boot up disk. You will have to get one mailed to you or you will have to use another computer to download one. This will get you back into a point that you can do a windows restore. This is going to get rid of all programs and start you fresh. I do, however, feel that you disk drive is going out or already shot. You should do a Chkdsk on it. (check disk). This will tell you if it is a hard drive error or not.
Jan 09, 2015 | Computers & Internet
Parameter out of normal operating range, computer will not boot up
Probably need to replace the hard drive and reinstall your operating system. Can you boot from a cd? Do a hard drive test and post the results.
Feb 24, 2014 | Microsoft Windows Vista Home Premium with...
Operating system not found
hi goodner,
getting the error "operating system not found" means that the hard drive where the Operating System is installed (i.e. Windows XP, Windows Vista, Windows 7), Cannot be found by you BIOS upon the boot sequence.
When you turn the PC/Laptop, you normal see a screen that flashes flashes with screen that displays the ff:
Primary Master:
Primary Slave:
Secondary Master:
Secondary Slave:
The Primary master should have a value right next to it. If not, either the hard drive is faulty and needs replacement, cable is loose,
If you have a value to it and stil gets the same error the operating is corrupted and needs to be re-installed.
Jan 29, 2013 | Computers & Internet
IMac screen goes black upon startup
Try a PRAM reset. Probably more than once. http://support.apple.com/kb/HT1379
Sep 30, 2012 | Apple iMac 24 inch 2.4GHz/ 1x1GB/ 320GB/...
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
My computer starts on black screen... drive 1 not found: serial ATA, SATA-2.. strike the F1 to continue, F2 to run.. if i press F1 it says NTLDR is missing what di i do? I have the operating sys. disk..
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Feb 03, 2011 | Dell Dimension E310 PC Desktop
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Dell Dimension E310 PC Desktop Logo
47 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
