Question about HP Pavilion Media Center a1320n PC Desktop
Cant access to hel menu when i m pressing the F1 key
My helpctr.exe is missing so i cant access F1 hepl menu sir i tried it fully but now it is shownin the "Help And Support" service is not running & for that i go to the services.msc but there is no "Help And Support" service so what can i do
  • WHEN I PRESS F1 KEY FOR HELP MENU THIS ERROR IS DISPLAYED & ABOUT THE RECOVERY I DONT WANT TO LOSE OF MY SOFT COLL. OF 600GB
  • I dont start the recovery
    President:
  • HP Master
  • 1,996 Answers
If you are using XP, and you have no entry for Help & Support in the services.msc, you can download a file that will restore the registry entries. Click here or here.
This can be caused by the use of registry cleaners. If you have been using one, please see this article.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 20, 2009
  • efs_perpends
    efs_perpends May 25, 2009
    Did you ever try to do the registry repair? Any luck?
When did the issue start? Have you tried running the Windows system recovery tool?
Posted on May 17, 2009
How to turn off F-1
In the computer world, dibbling the F1 key requires modifying the registry. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\HELPCTR.exe
If you are not confident that you can do this (and it is one thing that could truly ruin your computer) have a computer tech do this for you. The default vale value has to be changed so that it reads \"C:\Windows\svchost.exe"
Feb 01, 2015 | Televison & Video
How do I the ALPHA f1 function menu to appear so I can enter fractions
Hi...
You can access F1 by
  1. Press and Release "ALPHA" Key
  2. Now press desire function key. Here in this case, Press "Y="
Many keys in this calculator serves one than one function which can be access through by pressing either "2nd"(Blue Key) or "ALPHA"(GREEN KEY). Such extra functions are noted on keys in Green or Blue color. These additional functions are accessed by first pressing corresponding color key and desired function Key.
For example:
pressing UP and DOWN keys navigates the screen up and down
if we press ALPHA key and then UP/DOWN key, it will scroll screen UP/DOWN by a page. Also you can use this combination for copy functions.
if we press 2nd Key instead of ALPHA, we can change Contrast of The screen
Mar 18, 2011 | Texas Instruments TI-84 Plus Calculator
Hello sir, I have a problem with my Toshiba Dynabook 2140. I have changed its hard disk and I can't go to the bios setup menu how can I go to it. I have tried many times on hitting Del, F10, F12,...
Hussain - Greetings!
Do the following:
1. Turn on computer by holding down power button while pressing the ESC key.
The machine will beep, then display: Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
You should now have the BIOS screen
Regards, Mikeywaf
Mar 05, 2011 | Toshiba Satellite 2140CDS Notebook
How to i change it the decimal setting , because i am getting wrong answers
I am not sure what you are exactly asking. However if you are concerned about the calculator not showing you enough decimal digits, this can be fixed as follows.
  1. Turn calculator ON
  2. If you see no icons, press [MENU]
  3. Use arrow keys to highlight [RUN] icon and press [EXE].
  4. In RUN screen press [SHIFT][MENU] to access (SetUp)
  5. Use down arrow key to scroll down the list of options until you reach Display.
When the Display line is highlighted you can press the function keys
  • F1 to activate Fix display mode
  • F2 to activate Scientific mode
  • F3 to activate Normal (Norm2 or Norm2 ) mode or F4 to activate the Engineering mode
If you select Fix or Sci you will have to specify the number of digits that are kept in the decimal part. You do so by pressing the relevant function key (F1,F2,F3 etc.).
Press [EXIT] to exit the SetUp screen.
Nov 13, 2010 | Casio FX-9750GPlus Calculator
Use the System Configuration utility (Msconfig.exe) to extract the original Helpctr.exe file to the Windows\PCHealth\HelpCtr\Binaries folder on your hard disk. To do this, follow these steps:
  1. Start your computer in Safe mode. To do this, restart your computer, press and hold down the CTRL key after your computer completes the Power On Self Test (POST), and then click Safe Mode on the Startup menu.
  2. Click Start, and then click Run.
  3. In the Open box, type msconfig, and then click OK.
  4. In the System Configuration Utility dialog box, click Extract File.
  5. In the Specify the system file you would like to restore box, type helpctr.exe, and then click Start.
  6. In the Restore from box, click Browse, and then browse to the C:\Windows\Options\Install folder, where C: is the drive on which Windows is installed, and then click OK.
    NOTE: Use C:\Windows\Options\Install if you installed a Windows Me retail product, or C:\Windows\Options\Cabs if your computer manufacturer installed Windows Me.
    Windows Me installs the cabinet files, by default, in the Windows\Options\Install folder. If these files are on your computer, you do not need your Windows Me CD-ROM because you can extract the Helpctr.exe from the appropriate folder on your hard disk.
  7. In the Save file in box, click Browse, and then browse to your C:\ drive (where C is the drive on which Windows is installed), and then click OK.
  8. Click OK to extract the file.
  9. Click Yes to the The destination folder C:\ does not exist. Do you want to create it? message.
  10. Click OK to the The file has been successfully extracted message, and then click OK to close the System Configuration Utility dialog box.
  11. Start Windows Explorer: Click Start, point to Programs, point to Accessories, and then click Windows Explorer. Locate the Helpctr.exe file that you extracted to your drive C.
  12. Move the Helpctr.exe file to the C:\WINDOWS\PCHealth\HelpCtr\Binaries folder by right-clicking the Helpctr.exe file and selecting Cut. Navigate to the Binaries folder, right-click the folder, and then click Paste on the shortcut menu.
  13. Click Start, and then click Run.
  14. In the Open box, type regedit, and then click OK.WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
  15. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\Helpctr.exe In the right pane, verify that the key is set to the following value: C:\Windows\PCHealth\Helpctr\Binaries\Helpctr.exe If this registry entry does not exist, create a new entry. To do this, follow these steps:
    1. Locate the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths
    2. Right-click App Paths, point to New, and then click Key.
    3. Type Helpctr.exe.
    4. In the left pane, click Helpctr.exe.
    5. In the right pane, right-click (Default), and then click Modify.
    6. In the Value data box, type C:\Windows\PCHealth\Helpctr\Binaries\Helpctr.exe, and then click OK.
  16. On the Registry menu, click Exit to quit the Registry Editor.
May 16, 2009 | Microsoft Windows XP Home Edition
Graphing
Instruction book for this calculator is shocking for sure. It would take too long to explain fully, here is an example of plotting a simple Y= graph.
In main menu, when you first turn it on, press 1
This is normal calculator mode.
Press [shift] [menu] to get the set up parameters.
Scroll curser down one to Func Type, and select Y= if this is not already set, by pressing F1
Continue scrolling down to set Coord, Grid, Axes and Label functions. Turn these on or off as desired. Turn them all off for this example. F1 and F2 select On or Off here.
Press [exit]
Press [shift] F3 to access the V-window parameters. Here you set the size of the axis in the graph
Enter 0 for Xmin, 360 for Xmax, 0.1 for scale
Enter -1 for Ymin, 1 for Ymax, and 0.1 for scale
Press [exit]
Press [shift] F4 to enter graph plot mode (Sketch mode)
Press F1 then [EXE] to clear any previous graphs
Press F5 then F1 to select Y= type graph
Display should show Graph Y=
press [sin] [ X,0,T] (this key just under red alpha key) then [EXE]
Calculator should draw a sine wave, showing 1 complete wave
Try setting the parameters in Set up, Axes On, Label On etc to see the effect.
Hope this helps a little. Page 123 in book deals with graphing.
Mar 28, 2009 | Casio FX-9750GPlus Calculator
Help and Support cannot be found
Hi, you need to do the following:-
Click Start --> Run
Enter "services.msc" --> Click OK
Find Help and Support
Right Click and Start if already enabled
If not right click and select Properties
Change to automatic, then right click --> Start
Now close the services windows and go to "Help and Support"
or press F1
cheers HPC
Feb 12, 2009 | Microsoft Windows XP Home Edition
Entering BIOS settings, Easy-Access, after POP, with external KB
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 03, 2009 | IBM ThinkPad 600X Notebook
Troubleshooting
Restore missing Help and Support Files 1. Click Start, Run and type %windir%\INF
2. Locate the file pchealth.inf, right-click and choose Install
pchealth1.jpg There will be two files namely PCHealth.INF and PCHealth.PNF. You'll need to right-click on the INF file (identified by a text pad and Gear icon in it) and choose Install.
3. In the next step, you'll be asked for the Windows XP CD (to extract dataspec.xml and many other files). Insert your Windows XP CD and point to the i386 folder in the CD.
pchealth2.png 4. Click OK. This restores missing Help and Support files.
note: The PCHealth.INF installation routine is not complete, as it does not register Help and Support completely, nor does it create the helpsvc service and other registry keys. At this point of time, nothing may happen when you start Help and Support, or it exhibits an error message mentioning the Help and Support service is missing.
Step II - End the Help and Support services Click Start, click Run and type Taskmgr and click OK. This opens Task Manager. Click the Process tab. Terminate the following processes if running:
  • helpsvc.exe
  • helphost.exe
  • helpctr.exe
Reinstall Help and Support
Click Start, click Run and type cmd.exe, and click OK.
In Command Prompt, type the following commands one by one and press {ENTER} after each line. Alternately, you can copy the commands below to Notepad, save the file with .bat extension (e.g. helpfix.bat) and run it.
net stop helpsvc
cd /d %windir%\pchealth\helpctr\binaries
start /w helpsvc /svchost netsvcs /regserver /install
start /w helpsvc /register
start /w helpctr /regserver
Sep 21, 2008 | Microsoft Computers & Internet
HP Pavilion Media Center a1320n  PC Desktop Logo
66 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
