Question about Kitchen Ranges
No gas getting to oven or broiler stovetop works glow plugs work on oven and broiler recently move applianc for cleaning took warmer drawer out and vaccuumed in there thought maybe i loosened a wire cannot find any loose wires
    Problem Solver:
  • 8 Answers
It's usually the glowbar igniter in the oven. You can test the power draw going to the glowbar by using a clamp-on ampmeter. The draw varies (do a Google search for exact specs) but it should usually be between 3.2 and 3.7 amps. Anything lower than that means your glowbar is faulty and should be replaced. You can get replacements online for between $50 and $75 depending on brand. Replacing the glowbar is fairly easy and should take a novice about 15 minutes. Note that the glowbar can still glow brightly even if it is faulty. The glowbar not only ignites the gas but it also regulates the amount of gas entering the oven. This is why sometimes the oven will heat up but it takes forever to heat. Sometimes you will also smell unburned gas with a faulty glowbar.
Posted on Jul 30, 2009
  • 10,865 Answers
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Posted on May 17, 2009
  • 3 more comments
  • Joe Hogan May 17, 2009
    Other causes
    Other causes
    Other causes
    Other causes
    Other causes
SOURCE:
My stovetop works but my oven will not ignite.
Try this...open broiler door while initiating an oven start...look to the rear inside the broiler...there should be a reddish glow occuring...if not, then the ignitor may have gone bad...these are available from appliance parts stores or online
Dec 20, 2010 | Whirlpool Accubake SF362LXTS Kitchen Range
Oven not working. Top, broiler, and warmer are working.
Have you checked for proper gas flow into the over or broiler? This is a gas valve back there that will sometimes go bad. Also there is a sensor near your knobs, it is a timer that will go bad, the valve is about 85 dollars and the timer is about 65 dollars
Feb 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not work - Hi/Lo broiler works fine
you have a bad bake ignitor. it is mounted to the long tube in the very back wall of the tube. usually held on by 2 1/4 inch bolts. usually if you replace the ignitor you have to cut the old one off and hard wire the new one in depending on what the new connection on you ignitor look like.
Jan 26, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven and Broiler not working
The gas supply valve to the oven/broiler is the likely culprit. It is a separate valve from the stovetop. I've had the same problems and had to replace mine twice now. They are very expensive, (about 100 dollars) considering the cost of the whole stove. It is located
inside the broiler drawer on the very back wall.
Jan 01, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Kenmore Propane Range won't bake
The glow plug underneath the over floor need to be replaced
Dec 19, 2008 | Kenmore 36665 / 36669 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
SEARS GAS STOVE MODEL#79072114100.OVEN WONT LIGHT,IGNITER GLOWS BUT NO GAS COMES OUT.IS THE GAS VALVE UNDER THE BURNER WITH THE 2 WIRES ON IT? VIC
i had the same problem ( ignitor glows but no gas) on sears model
79071012300. i replaced the ignitor (glow bar) and the oven lit within 10-15 seconds! it was easy to replace and it took longer to figure out how to get the broiler drawer out of my way than it took to replace the ignitor.
Jul 18, 2008 | Kitchen Ranges
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Kitchen Ranges Logo
462 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
