Question about Electronics - Others
Model adaptor mix Phonic mu1202 outpu volt - Electronics - Others
2 Suggested Answers
eg17
  • 17 Answers
SOURCE: how many volt? for power supply phonic mixer MM 1202
http://www.bandl.hu/pdf/audio/mixer/phonic_mm1202a.pdf
Here's the answer
Posted on Mar 31, 2013
I have a model-JJB052000-2509 50/60 H2 Output5V-2000mA and I need power adaptor can you help me?
pls let me know where do u live,,you need 5volt 2 ampere adaptor,,u may use 2-5 ampere also,,volts should be =5 volts,,,u can charge ur note with laptop usb connector also,,,or u can find this adaptor on amazon.com,,,ali express,,,or any other as per ur area
Jan 27, 2015 | Archos 101 Internet Tablet 16GB 10.1"...
How many volt , ac.or dc. for power supply phonic MM1202 mixer
I tells the power supply model numbers on the back of the unit above the power connector plug. It doesn't tell the specs as of how many amps but does describe several voltages of AC it would work on and also gives several model numbers of the correct power units that are sufficient. If you don't use one the recommended units, it could malfunction and give extra static noises caused by improper filtering of the power. It shows on page 8 of this manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=39&ved=0CHkQFjAIOB4&url=http%3A%2F%2Fsoundhouse.co.kr%2Fsoundh%2Fcatalog%2FPHONIC%2Fmixer%2FM-U-1-2-0-2_1-2-0-2-X_om.pdf&ei=QPdbUaX3K4zA9gS11IFY&usg=AFQjCNGoMutp27pESma_-Mw36637hlmHOA&sig2=8J0-4rb6sHlit-OdKlIFbg
I hope this helps you.
Mar 31, 2013 | Phonic Music
Can phonic xp 5000 or xp 5100 amplifier use 220 volts?
Hi i have a phonic mar 6 its clipin at low volume what could be the problem
Feb 01, 2011 | Phonic - XP 5100 - 5000 Watt Power...
I have speakers plugged into my phonic powerpod 820 right now but I want also to have the output of the mixer to go through an instrument amp, is this possible? If so, where do I connect the instrument amp...
Yes it's possible. I'm assuming you'd like to use the keyboard amp as a "monitor". In which case, take a 1/4inch TS (instrument cable) jack out of "Aux Send" into the input of your keyboard amp. Make sure the keyboard amp is turned up to a good level and that the Master SEND is turned up on the Desk.
Now you can make your own "monitor mix" for on stage use without effecting the F.O.H mix by turning up the aux pot (knob) on each channel you use.
You can use the CTRL ROOM output also, but make sure it's not giving a "Powered Output" from the internal amplifier in the mixer as you will damage the keyboard amp.
Jan 16, 2011 | Phonic Powerpod 820 / S712 PA Package
Hello, i need phonic max 2500 plus diagram
  • 860/1500/2500 MAX 860/1500/2500
    archive.espec.ws/.../PHONIC%20MAX-%20860%201...
    Traduire cette page Phonic reserves the right to improve or alter any information supplied within ... MAX860/1500/2500 SERVICE MANUAL ..... HEAT SINK MAX SERIES PHONIC.
  • PHONIC max 2500 - Service Manual free download ...
    www.eserviceinfo.com/index.php?...PHONIC+max+2...
    Traduire cette page 15 janv. 2009 - Search results for: PHONIC max 2500 (found: 50 regularSearch) ... Audio, 2891 kB, 2178, Service Manual, PHONIC max 2500, VASILICH500.
  • Amplifiers :: Analog :: MAX 2500 Plus - Phonic ...
    www.phonic.com > Home > Amplifiers > Analog
    Traduire cette page Phonic's MAX 2500 Plus Power Amplifier provides 1500 Watts of power at 8 ohms (bridge mono) or 750 ... MAX 2500 Plus Simplified Chinese User's Manual.
  • PHONIC MAX 860 1500 2500 Service Manual free ...
    elektrotanya.com/phonic_max...2500.../download.ht...
    Traduire cette page PHONIC MAX 860 1500 2500. Sponsored link. Type: (PDF), Size 2.9 MB, Page 27, Category: AUDIO - SERVICE MANUAL. Warning! If you are not fa
  • Nov 19, 2010 | Phonic MAX 2500 Amplifier
    I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
    The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
    You need to find a competent electronics repair person.
    Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
    Phonic Max2500
    you have real problem in safety contol circuit which shut down the unit to protect the amplifier from damage
    Mar 06, 2008 | Phonic MAX 2500 Amplifier
    How to hook the eq up??
    take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
    Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
    Electronics - Others Logo
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
