Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Melted plastic lid in oven - how can I remove it
I melted a clear plastic lid in my oven, how do I get it off the bottom of the oven and of the racks
  • 10,865 Answers
Any oven cleaner, like easy off will work on this but it may take more than one application. You can actually begin with your hair blow dryer and a putty knife by heating the plastic up enough to scrape most of it off. Then let the oven cleaner do the rest.
Posted on May 20, 2009
The plastic ties were left on the oven rack. One melted . How do I get the plastic off the bottom of a self cleaning oven?
Warm Method Both Good Housekeeping and the website Hunker describe this method for self-cleaning ovens. Hunker warns to NOT use the "cold method" which is reserved for other types of ovens. And the Good Housekeeping site says if the method proves unsatisfactory, that the floor or bottom plate of the oven might have to be replaced.
(That said, I suspect if you pull out oven racks and apply some ice to any plastic on it, the plastic might become brittle enough that tapping it with a spoon and prying at it with something wooden or finger nails might remove a lot of it. No scraping with the spoon!)
Here is the primary process for the oven.
Self-cleaning ovens require heat to remove the melted plastic. This method also works on heating elements with plastic on them. Step 1 Turn the oven on to the lowest heat setting. Only leave the oven on long enough to make the plastic soft and pliable.
Step 2 Scrape the melted plastic with a wooden utensil such as a spatula or spoon. The wood protects the surface inside the self-cleaning oven. When you get all off that you can, the self cleaning feature may burn off the rest. That WILL be smokey and exude an unpleasant smell while it does it. Open windows and keep pets out of the area (and yourself) while it goes through the clean cycle. Do NOT use a screw driver to try and remove the plastic.
Aug 26, 2017 | Ovens
A black plastic meat container melted all over the bottom of the oven ,can I self clean the oven once it cools will it come clean?
not safe, the plastic will most likely release toxic fumes when heated that hot Try warming the oven until the plastic is soft, then scrape it off.
Apr 20, 2016 | Ovens
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
We too ended up with melted reynolds wrap standard aluminum foil lined and then melted to the bottom of our oven. The smell was terrible. The thing was, we didn't know it was the aluminum foil until we had...
It is very difficult to melt Teflon; 326.8 degrees Celsius or 623.24 degrees Fahrenheit, hotter than most ovens! Rapeseed cooking oil will have long before caught fire.
Teflon is not used on oven floors, walls or racks.
The melting temperature of aluminium foil is 660 degrees Celsius (1,220 degrees Fahrenheit) at standard pressure, so it won't melt with temperatures encountered in a standard household oven!
Toxic fumes from the Teflon chemical released from pots and pans at high temperatures may kill pet birds and cause people to develop flu-like symptoms (called "Teflon Flu" or, as scientists describe it, "Polymer fume fever").
Oct 15, 2017 | Ovens
How to clean after an oven fire
Cheryl,
If you can't scrape the plastic off then heating it up to soften it is about your only choice short of putting it back in self clean with a fan in the nearest window blowing outside to evacuate the smoke. Depending how bad it is and how cold it is where you live, you might even try freezing if off. Get it as cold as possible and see if the cold makes it easier to chip off. As far as the element, I suggest turning the oven on and letting it smoke and burn clean. Shouldn't be a very long process since the element will get hot so fast the plastic will drip off right away.
Hope that helps... Brian
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You WILL damage the panel. The only option you have is to replace the panel or the entire oven liner...
May 20, 2008 | Ovens
Gas oven - - melted plastic inside
You can remove the bottom oven panel and look under it. All you have to do is remove the oven racks and locate the screws that hold the bottom panel in place. MOST ovens only have two of them. Once you have the crews removed, the panel slides back a bit, then lifts up. If there are any heavy deposits of melted plastic, remove it like you did before. Any residual material can be taken off with some fine emery paper. Wear a dust mask and vacuum all the dust out of the oven. DO NOT use this method on the oven wall as it may scatch it. This is only for anything that may have dripped below the oven pan. You may have an odor to the oven for a while, but as long as you have nothing else melted inside this should go away. Try running it on a cleaning cycle AFTER you've inspected the oven & cleaned out the remaining plastic. This will burn off anything left behind. I hope this helps you.
Feb 12, 2008 | Ovens
Tin foil melted in my oven.
hi floppy,
if you can't scrape most of it off with a plastic scraper, you may have to buy a new bottom pan. if you can get most of it off it should be ok to use. also if you have propane gas make sure your stove was converted properly.
Dec 04, 2007 | Kenmore 33169 Gas Single Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
442 people viewed this question
Top Jenn-Air Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
