Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Ryobi 3043 Strimmer won't idle after strip-down.
My Ryobi PLT-3043YE strimmer will not idle and needs 1/2 throttle to keep running.
This was not the original problem - yesterday it would not reach full speed after 10 minutes use, but idled OK, and eventually would only reach 1/3 of normal revs on full throttle. I pulled the carb and removed the bottom cover - it was immaculate inside and the float & diaphragm seemed fine so I refitted it. Then I checked the spark arrester, which was completely clogged with carbon - so I cleaned and reassembled it. Now it runs fine at full throttle but stalls on less than half throttle.
I suspect that the idle jet/passages got a bit of dirt in when I took the bottom off the carb. I've twice tried blowing it out - no effect. Looking for ideas!
  • 3 more comments
  • Gnomeface May 18, 2009
    Josh1111 - the carb screws have "tamper-proof" plastic covers that only allow the mixture to be weakened, by 1/4 turn. I tried altering them as far as possible (no effect) then reset them to the original positions. The trimmer idled fine before I opened the float chamber briefly (and it isn't very old) so shouldn't need adjustment - and as it needs almost 1/2 throttle to keep it running I'm thinking that it must be more then a simple adjustment issue. I'm considering of cutting off the anti-tamper covers, removing the idle screw completely, then either blowing through with compressed air or using a fine brush bristle to poke through the airways.
    OK, it's fixed. I found out how to remove the anti-tamper guards from the adjusting screws and removed the screws, blew through and used a brush bristle to check the tiny holes were clear, and reassembled. It started OK and after adjusting the screws it runs better then ever. Seems I'll have to clean the spark arrester every year though.
  • ascpipo May 21, 2009
    I have the same problem with my Ryobi 3043. Can you explain where the spark arrester and idle screws are located?
  • josh1111 May 11, 2010
    did you adjust the carb screws correctly?
5 Suggested Answers
  • 148 Answers
SOURCE: RLT30HT 30CC PETROL STRIMMER difficult to start
The plug that I have in my 720r is a Champion RDJ7Y. Can I suggest that you pull the old plug out and look to see which one you have? Also when you buy the new replacement it should already be gapped for what you need.
Posted on Jul 28, 2009
jowen28
  • 9 Answers
SOURCE: Have the RLT30HT strimmer. Hard
Something is causing a lean mixture (less fuel) at the carb. Usually a furl flow problem - do the easy things first - check fuel tank foe any leaks (cracks in plastic) fuel lines for being dark yellow or brown colored - they will begin splitting apart at this point. Then go after the fuel primer bulb - if darkened then replace it - about $4 at hardware stores. Then take a look at the muffler - there will be a spark arresting screen at its outlet - remove the exhaust snout and lose the screen - doesn't run with that screen plugged up!! Now start it back up and you might just be surprised!
If it still does not run well unless you partially choke it, turn the fuel mixture screw a quarter turn outward to admit more fuel into the carburetor. Do this until the RPM increases - careful not to go too rich - can foul out the plug! Find the sweet spot. Hope this helps you.
Posted on Jun 21, 2011
  • 6 Answers
SOURCE: My Ryobi strimmer will not start. It has never
You need to have someone clean the carburetor.
Posted on Jun 28, 2011
mark24354
  • 776 Answers
SOURCE: ryobi RY09440 4 cycle blow will run great for 10
You choke lever may be stuck (or the choke plate is stuch on the carburetor).
Posted on Sep 24, 2011
Where can i get a piston ring for ryobi strimmer,its a 25cc,model number PLT 2543.
Some of these small engines have very limited parts availability so that part may not be available. Try www.jackssmallengine.com
Oct 27, 2016 | Ryobi Garden
Jcb strimmer plt 25f
If there is a spark at the plug, and the plug gets wet with fuel after pulling, the remove the muffler and check the condition of the piston through the open exhaust port, if there is any signs of scuffing then the motor has seized and will require stripping down, if the piston looks good, check the fly wheel key has not part sheared, they are usually alloy and part of the flywheel itself.
Jun 02, 2013 | Garden
Hi, I have a Ryobi PBC 3046YB strimmer/brushcutter, which worked perfectly well in its first season, used about 10 times. When first used the following season, the machine would start easily, but when I...
This does not sound like an air leak, normally an air leak will cause fast uncontrollable idle, if it sounds muffled i would be looking at a blocked spark arrestor, or exhaust port, or muffler.Slacken the muffler right off and just try running it to see if it picks up normally.
Jul 18, 2011 | Ryobi Garden
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
What is the 2 stroke petrol mix for a garden strimmer, Ryobi 25cc PLT 2543 please?
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Jun 02, 2011 | Garden
Strimmer will not start got spark & fuel ryobi rbc30sbt
its probabley your throttle cable , try pulling the throttle full on when you starting up the trimmer word of warning though only do this on a very flat surface..
Nov 23, 2010 | Ryobi Garden
My Ryobi PLT 2543 strimmer will run, but cuts out when the throttle is opened
I had this problem twice in the past. I solved it the first time by replacingthe plug and setting the plug gap with a feeler guage. The next time it was a decoke of the cylinder (squirting through the plug hole) replacing the plug and leaving it overnight and then cleaning the air filter. It runs like a dream and has worked in Australia, Europe and the UK with no further problems. Also the fule mix has to be just right, I actually use 22:1 instead of 25:1 and do not use any petrol / gas with additives in (like Shell).
Aug 29, 2009 | Ryobi Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
629 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
