Question about Whirlpool (ET1MTKXKQ) Top Freezer Refrigerator
I m trying to install a Whirlpool probe kit 819043 in a Whirlpool refrigerator Model no ET1CHMXKB. It was bought from Lowes in 2004 The freezer drain pan appears to be accessed from below the freezer.I am unsure of how to access it to insert the heat probe. Any advice welcomed. NickC
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool GD25DF auto defrost drain problem
There is a drain hole in the back of the freezer on the bottom. Get back there with some hot water. Most of the time it is just lime build up. Unless you know what feel back there. Another way is to move the freezer out and from the back side you can see the drain line. It just pulls right off
Posted on Feb 11, 2009
  • 117 Answers
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Posted on Feb 25, 2009
jumptrout51
  • 3361 Answers
SOURCE: Can't get to drain pan for cleaning, whirlpool fridge
You can not acces the drain pan. Por 1/4 cup bleach in the defrost drain hole.
Two days later pour 1/4 cup vinegar in the defrost drain hole.
Posted on Mar 19, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
Water is leaking from freezer into refrigerator. we have no icemaker. we think model number is 134a
sounds like a drain that has iced over .. you need to install a drain heater kit . pt # 819043 this will stop the problem .. you will have to clean out all the ice in freezer . remove back and install kit as per instructions .. .. mm hope this helped .. feed bacl pls .. ps the # 134a is the gas that the unit uses .
Jul 10, 2011 | Kenmore Refrigerators
Fridge is leaking water from the inside, on the back wall
Your freezer drain is clogged or frozen up with ice blockage. Need to remove the freezer floor liner, usually 2-4 1/4" screws holding it in - slide it out. Next slowly pour hot water over ice build up and melt all ice. The drain is under the evaporator coils (small hole near center) this connects to a pan under the refrigerator that then evaporates on its own. I usually place a couple of bowls inside fresh food area on top shelf to catch excess water dripping through ceiling of fresh foods.
Next you will need to attach a heat probe from the heater under the freezer coils and feed it into the drain in order to prevent freezing up again. Use part #819043 heat probe or strip some #14 gauge copper wire and wrap around heater once and place down through drain. Recommend the heat probe 819043 to get it right the first time.
Jan 30, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
At times, there is water that freezes under the vegetable/fruit drawers that are at the bottom of the refrigerator. Also, at times there may be a thin layer of ice on the floor of the top freezer. I'm...
Jan 30, 2011 | Roper RT21SKXLQ Top Freezer Refrigerator
I have ice buildup in the freezer which is leaking into the refrigerator. I have a Whirlpool model ET8CHMXKB05
YOUR DEFROST DRAIN IS CLOGGED IN YOUR FREEZER. UNPLUG UNIT. REMOVE BACK WALL OF FREEZER. REMOVE FREEZER FLOOR SOME DO NOT COME OUT. REMOVE ALL ICE. IN THE DRAIN TROFF USE WARM WATER OR HAIR DRYER. KEEP FREEZER 0-6 DEGREES. IF PROBLEM REOCCURS THERE IS A HET PROBE TO KEEP DRAIN HOLE CLEAR. PART NUMBER 819043
Apr 25, 2010 | Refrigerators
Water builds up under the crisper drawers and I dont know why?
probably a frozen drain hole in the freezer. a heat probe usually has to be inserted to prevent the drain hole from freezing shut. part # 819043.
Feb 28, 2010 | Whirlpool Refrigerators
Leaking water from the freezer into the fridge
remove back of freezer and defrost with hair dryer . force hot water down the drain to clear and use add on drain heater kit to stop the problem whirl pt # 819043 heat prob kit .. hope this hepled mm / feed back pls .
Feb 03, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My Kenmore refrigerator defrost drain freezes over.
There is a heat probe kit available to help prevent the drain hole from freezing shut. Part # 819043.
Jan 29, 2010 | Kenmore Refrigerators
Water is dripping from freezer to shelves in fridge
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
Jan 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
In the frezzer ice is forming under the floor and dripping down onto the floor of the refrigerator part under the veg drawers
May 05, 2009 | Kenmore Refrigerators
Whirlpool (ET1MTKXKQ) Top Freezer Refrigerator Logo
400 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
