Question about Hotpoint WM56 Front Load Washer
Knocking during spin and now tripping electricity on startup
Hotpoint WM56 Washing Machine. In the last week or so it has started knocking or banging during the spin cycle but was otherwise running correctly. Today though, when it starts the cycle, it trips the mains circuit. we have tried another socket but to no avail. I have taken the washer apart. I can't see any obvious damage to the electrics and the interlock on the door seems reasonably clean and dry. I did notice that a small amount of water had accumulated at the bottom of the chassis at the front dead centre. The seal was replaced moderately recently (last year or so) and looks okay though it is very slightly deformed near the door lock. Does anybody have any ideas? Thanks
    Habit-Forming:
    New Friend:
  • 31 Answers
It sounds as though you may have a problem with the heater, either it has come loose or been damaged during the noisy section of the spin which could have been a coin or foreign object in the drum, assuming there is no problem with the bearings. It's best if you can test the heater with an electrical test meter having first removed the wires, place one connector on one of the terminals and touch the heater casing with the other, if you get a reading the heater is shorting out. If it is the heater it may have been forced out of the front plate which could have caused a crack in it so check for any damage
Posted on Mar 30, 2017
3 Suggested Answers
  • 209 Answers
SOURCE: Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
Posted on Oct 03, 2007
  • 166 Answers
SOURCE: hotpoint washing machine keeps tripping electric
First unplug your washer. Check the ground on the washer and make sure it isn't loose; this would be a good time to inspect the wiring harness for any problems. Next check the outlet (turn off the electric to that breaker first) make sure all the wires are tight and are making good contact; pay special attention to the neutral (white) wire. If that seems fine, and you are comfortable with going into you breaker panel, turn off that breaker and check the hot (the wire on the breaker) to make sure it isn't loose and then check the neutral wire. If either of these wires seem loose tighten them down....a loose wire will move when a load is put on it and cause the breaker to trip. If all seems normal and washer is still tripping the breaker you might want to replace the breaker.....they can go bad. Good luck!
Posted on Aug 26, 2009
Hotpoint Aquarius wm61 trips as soon as its filled with water,if I remove alot of the water it will allow me to spin
If you mean that the machine is tripping the circuit breaker then that is an indication that the water is creating an electrical current path to Earth. The heating element is normally enclosed in a metal sheath but if this is compromised then water will get in and current will then leak to earth, causing the circuit breaker to trip. The heating element can be replaced, but the cause of the damage to the element should also be determined to prevent it happening again. The rotating drum can become partially detached from it's mount and end up hitting the heating element when spinning, causing the element to be damaged. The drum mount (often called a SPIDER) may therefore also need replacing. If you machine was making a lot of knocking noises when in spin cycle then it would certainly indicate a broken mount.
Feb 08, 2016 | Hotpoint Washing Machines
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
Jan 20, 2012 | Hotpoint WMA44 Front Load Washer
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint WM56 Front Load Washer Logo
85 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
