Question about GE Microwave Ovens
Over the range microwave charcoal filer
JVM6172DF1
2 Suggested Answers
  • 4 Answers
SOURCE: need help selecting proper charcoal filter
It's Part No. WB06X10359.
Posted on Jul 18, 2009
How to remove grease filter from a Samsung over the range microwave model number smh8165st
The support page for model SMH8165S is here, and the first solution listed is how to replace the charcoal filter.
You can also download your owner's manual.
The charcoal filter is part number DE63-00367A and you can order it from the Pros here.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
May 01, 2017 | Samsung Microwave Ovens
How do you remove grease filter from Samsung over the range microwave model number smh8165st?h
pupista@gmail.com
I cannot find where to put the charcoal filter, please help. My overhead range microwave is a Samsung
We would need your model number form the tag in the cooking cavity, etc. to be able to help you.
William Edward Miller
pupista@gmail.com
microwavecontrol.com
Aug 12, 2016 | Samsung Microwave Ovens
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
Will not heat. ... Could not replacing the charcoal filter be a problem?
A microwave that fails to work usually needs either a fuse or a magnetron or a capacitor.
Oct 21, 2013 | GE Profile Spacemaker Over-the-Range...
We installed new microwave and don't know where the charcoal filter goes
Open the door and take off the upper side barre. and you are in bussnis
Sep 28, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Can't install my GE microwave charcoal filter.
Most or the ones I have seen just sort of lay in there at a bout a 45 degree angle. I can t say i have really ever seen one " snap" in place
Sep 27, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Wrong Grease Filter for Sharp R-1870 Microwave
I also have a Sharp over the Range Microwave oven that requires a charcoal filter. But my diagram shows that the charcoal filter goes behind the slotted panel at the top of the microwave. To reach the filter, you must remove a screw on the top edge of the microwave. This allows the panel to come off. Your charcoal filter goes there. Since your oven is new, you do not need to change this filter yet because it's not dirty. I would save it for future use.
According to my book, there are two kinds of filters with this oven. The charcoal filter is the one behind the front panel. The Grease filters ARE the two metal mesh ones. They can be cleaned with hot soapy water, or I put mine in the dishwasher.
Mar 14, 2009 | Sharp R-1480 Microwave Oven
Charcoal Filer for JVM1650BB008
If yours is part # WB2X9883, you can save about $10 on it here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 20, 2008 | GE JVM1650 1000 Watts Microwave Oven
Open Questions:
GE Microwave JVM1441BH04: Safe to reconnect replacement stirrer & turntable motors after accidentally burning out the turntable motor? GE JVM1441BH04 Over Stove Microwave: Tapping noise was coming from the 21v AC stirrer motor which sits atop the cooking chamber. I disconnected the two connecting leads, unfastened the single screw holding it on, placed in on my scanner glass to get a high rez photo of all the specifics listed on the motor label. Bad news: While waiting for the scan to finish, I warmed my coffee in the microwave on the highest heat for 30 seconds. I subsequently discovered the 21v AC turntable motor, which had been working just fine, was now no longer working, with infinite resistance across its terminals, and a burnt electrical smell. Both the stirrer and turntable motors are powered by a 24v tap off the magnetron fan. My theory: By running the microwave with the stirrer motor out of the circuit, I delivered excessive voltage to the turntable motor, which quickly fried. The 24v tap off the magnetron fan motor currently shows the correct 24v output. However, with both the stirrer motor and turntable motor disconnected, running the microwave for a few seconds shows approx 95v across the wire leads for both of the 21v motors. I have obtained replacement motors for both the noisy stirrer motor and the fried turntable motor. My question: Can I simply reconnect both motors in their proper locations, vow never again to run one without the other connected, and all will be well? Or will the newly installed motors simply be fried in a matter of seconds?
Jan 04, 2018 | GE Microwave Ovens
Microwave Ovens Logo
19 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
