Question about Kitchen Ranges
My smooth top range displays EO-F2- when i turn oven on
  • 1 more comment
  • francesev90 May 17, 2009
    the model is 9501
    kenmore ceran top range displays EO-F2- when oven is turned on model 9501
    fixya does not appear to be any assistance to me at this time i included brand and model thank you for time and effort
  • 6,784 Answers
The "F2 - E0" error code means "Shorted keypad". Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
Posted on May 17, 2009
  • 432 Answers
What make of machine is it - also do you have a start button on the oven ?
If so turn it off for a while and hold down the start button and turn it on still holding the start button for about 5 seconds.
Also if its a whirl pool if you check the manual they should have some troubleshooting guides which will
A -> tell you what that error means
B -> may tell you how to rectify if possible
C -> if it is not possible will tell you who to contact -> assuming it will be the manufacturer as it should come with a few years warranty or something along those lines so they may be able to send someone out if you call them and advise them of whats happened so they can repair it
D -> Can advise you how much it will cost and you will be better off getting the manufacturer to repair it that way you know the person they will send out will be a genuine person not a cowboy who may ruin it or make it worse.
If you manage to post back soon I can have a look in the manuals for you but if you go to the manufacturers website which is generally
www.manufacturer.com if not google for it and you should be able to find there website and go to there support / downloads section and you should be able to find the manuals there for your specific machine
  • 355 Answers
Which model are you using????
  • 163 Answers
What brand and model number oven do you have?
  • May 17, 2009
    This means you need to replace the ERC. This is the Electronic range control. Thats probably the mean of your fault code. Without knowing your model number I can't be sure though.
After cooking my whirlpool Electric Range started to beep and shows EO F2. The range top is working ( and range top controls ) but the oven won't shut off and the controls are not working for the oven.
Here is what my online service manual for the F2-EO error code says
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock)
I hope this helps
Gene
Aug 01, 2011 | Whirlpool Kitchen Ranges
Display reads EO -F2- stove top works, oven will not
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
EO F2 on our Kenmore oven keeps coming up.
May 15, 2009 | Kenmore Ovens
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
EO F2 code
THIS IS GENERALLY A BAD ELECTRONIC RANGE CONTROL OR ERC BOARD
Jun 01, 2008 | Kitchen Ranges
Control Panel Display Reading
mommaT, the code has to do with the keypad, key held down too long or stuck or shorted keypad. Have someone remove the key pad ribbon cable from the control board and clean the ends with an eraser. If that doesn't do it, you may need a new keypad. Catriver..post back
May 13, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
