Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7657AYW has no power or lights
Had seating for a while but was working, moved had to changed from 3 to 4 prong (red, white,black and green grounded to frame)
jsrock516
  • 5911 Answers
SOURCE: REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Posted on Feb 14, 2008
  • 101 Answers
SOURCE: Change 3 prong dryer cord to 4 prong
well the green wire is the earth ground,you could connect it to a pip,or to the outlet box.
Posted on May 11, 2008
jomabug76
  • 1148 Answers
SOURCE: Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Posted on Oct 05, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
  • 686 Answers
SOURCE: After conversion from 3 prong to 4 prong dryer wont work
YOUR FOUR WIRE CORD IS AS FOLLOWS RED,BLACK WHITE AND GREEN ON YOUR DRYER YOU HAVE FROM LEFT TO RIGHT 123 CONNECTIONS THE TWO OUTERMOST(1 AND 3) ARE HOT LEADS SO HOOK RED TO 1 AND BLACK TO 3 NOW HOOK WHITE TO 2 AND THE GREEN CAN BE ON THE TERMINAL COVER SCREW OR NOT AT ALL BUT BE SURE IT CANNOT COME INTO CONTACT WITH RED OR BLACK
Posted on Apr 28, 2009
Power cord replacement (3 prong to 4 prong)
Your new cord has 4 wires. Black, red, white , green.
The dryer has 3 lugs to connect to. Connect the white and green to the center lug, connect the red to left lug and the black to the right lug. You are all set to use dryer.
Jun 06, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Need diagram on wiring new 4 prong plug, to take the place of 3 prong plug. thanks
Your dryer block has 3 terminals . On your cord , put the white in the center terminal of your dryer block , red and black on either side ( makes no difference ) , and the green to the ground screw or the screw which holds the cover plate on .
Apr 27, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
I have a 3 prong cord, the outlet is 4, colors in back dont match
Hook the green directly to the metal of the machine anywhere you can, like under a screw that holds something.
Hook the white to the white.
Then the red and black can go on the other two, it does not natter which one is on what they are interchangable. To make it easy, go black on black and red on blue.
Plug it in and
Then you are good to go!!
Heatman101
Jan 20, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Moved dryer, hooked up wrong, not working now after re-hooked up
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
May 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Apr 27, 2009 | Estate TEDX640JQ Electric Dryer
How to change a 3 prong to a four prong on a mde4000 Maytag Neptu
the red wire to red black wire to black white wire to white and disconect the ground wire to the white lug and conect the green wire to the screw that is on the other end of the ground strap you disconected from the white lug
Dec 24, 2008 | Maytag Neptune MDE4000 Electric Dryer
3 prong to 4 prong on Maytag Neptune no heat no function
hi thanks for the question red to red black to black white to white green to the frame of the dryer thanks the appliance doc
Sep 28, 2008 | Maytag Neptune MDE6700A Electric Dryer
MAYTAG DRYER ELECTRICAL CONNECTION
how do you change a 3 prong plug to a 4 prong plug when the colors dont match on the wires to the dryer?colors on the wires are red white black and green. colors on the terminal of the dryer are a black and yellow tied together a white in the middle and 2 blues tied together. this is a maytag atlantis dryer. thankyou chad....
Jul 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Need to change the cord on my Maytag MDE6000AYW from 3 prong to 4 prong. The (4) prong cable has black, white, green, red cables. Which colored cable connects to which terminal inside the dryer?
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
Jul 13, 2008 | Maytag Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
120 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
