Question about Smeg CSU2001 Built-in Dishwasher
Smeg Allegra NZL750 drains water after wash but then it fills up bottom with water
Recently our Smeg Allegra NZL705 have been filling the bottom of the machine with water after it managed to drain it all after a wash cycle. I took the dishes out after the machine has finished and everything looked fine. The next day the bottom of the machine was filled with water (that looks clean). I left the machine turned on... could that be the problem? The basket is clean... could it be blocked somewhere else? What can I do?
Thanks,
Athena
4 Suggested Answers
  • 25 Answers
SOURCE: smeg DI 612CA
Take a look at this link http://www.smeg-service.co.uk/support/index.php?a=1&cat=4
Would seem to be the anti flooding device on the inlet hose
Posted on May 08, 2008
ginko
  • 19396 Answers
SOURCE: Machine won't drain fully
If the drain pump is working fine, and water flows from the machine and there are no clogged drain lines, then the problem is usually the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is too low then that is the problem.
Posted on Apr 07, 2009
57 varieties
  • 1653 Answers
SOURCE: no water filling dishwasher after paper napkin got
First turn off the mains power to the dishwasher then check the internal filter and screen and clean it thoroughly. Then check the waste water hose and any outlet valve and make sure that it is unblocked and free of any obstruction or waste material. If you have access to the water pump you can check that it is free of obstruction and is able to turn and that none of the impeller vanes have been damaged. Then if all this is OK then try turning on the mains power and running a hot wash cleaning cycle to flush out any remaining sludge / debris. If this fails and no water is entering the machine then the most likely cause of the problem will be a defective water inlet valve or logic controller board and both will need checking and / or replacing by a service engineer. In this case it is most likely that the water inlet valve has become defective and will need replacing. This is quite a common fault with dishwashers and washing machines and is a relatively simple and cheap repair.
Posted on Sep 24, 2009
Smeg Dishwasher constantly filling and tripping anti flood sensor
Fill solenoid if water constantly filling when power switched off. Level sensor in sump if just overfilling but stops when power off
Jan 19, 2018 | Smeg Washing Machines
Smeg Dishwasher not circulating water
Sound like the thermostat doesn't know what the water temperature is set at.
It could be the wash pump. Check to see that the float on the bottom of the DW is unstuck by gently picking it up and setting it down { It is shaped like a mushroom and controls the water level in the bottom of the DW }. Did it move freely?
Dec 29, 2013 | Dishwashers
Dishwasher cavitates. I have a Smeg DI612CA9
Does the drain hose loop up to the top of the unit before going to the sink drain? If it goes down first it may be siphoning or draining by gravity.
Aug 08, 2013 | Smeg Dishwashers
The door on my Smeg Allegra front-loader washing does not open
SOME MACHINES HAVE A DELAYED OPENING TIME SO THE DOOR DOSE NOT OPEN WHEN BUTTON PRESSED LOOK IN MANUNAL TO SEE IF THIS FEATURE IS ON MACHINE IF NOT PROBLEM THEN NEW DOOR LOCK WOULD BE IN ORDER
Dec 30, 2009 | Washing Machines
Smeg dishwasher not orking properly
if water is coming in the drain then you could have a bad check valve. when you open the dw at the end and there was no water it was because you were in the drying cycle and the eement was drying the water as it came in.
Jan 11, 2009 | Smeg CSU2001 Built-in Dishwasher
SA 660 SMEG dishwasher constantly filling....
this can be water draining from your sink into the dishwasher via the drain pipe, assuming the drain pipe goes to a spigot on the sink trap.
take the drain hose up as high as possible in a swan neck to prevent this.
Jul 17, 2008 | Dishwashers
Smeg washer/dryer not filling
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Mar 26, 2008 | Washing Machines
SMEG Dishwasher - Water fill level is too low
Hi, I found your problem stuck here from one year ago.
I will post my solution the same, as reference for you and more users with same problem, apologies.
Re: smeg dishwasher fails to fill with enough water to sucessfully wash. It does put some water in.. but nowhere near enough.
Before checking parts inside the machine, ensure that water is coming from the faucet at the back with regular pressure.
To start check the water level sensor.
Check if water level is working properly, if the floater is getting stuck then that is the problem.
If the water level is OK, then the responsible is usually the inlet valve, or clogged inlet lines.
From description it looks more like a faulty water level.
Mar 14, 2008 | Smeg CSU2001 Built-in Dishwasher
Smeg DI 612CA
Nov 19, 2007 | Smeg 24 in. STX2 Built-in Dishwasher
Smeg CSU2001 Built-in Dishwasher Logo
169 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
